Rear wiper broke
Vankonk
WI
Just upgraded using the info from this thread on my 16 EL limited. Bought off Amazon and took 5 mins to replace and it made a huge difference. Much better arm and wiper. Thanks for the info.
cvbrewer
Fairfield
Hey guys,
My factory arm is sagging down off the glass. I wasn't able to get it off to replace or realign. Was afraid to break the glass. If it is wedged on should I try a gear puller or something?
Thanks,
CV
Black
Kentucky
Hey guys,
Thanks,
CV
Spray the shaft with some WD-40 let it sit for a little bit.
Take a painters tool, A putty knife is too thin and flexible, slide between the arm base and the plastic area around the shaft area and wiggle it.
The arm will pop off and be pretty loud.
Warner ProGrip 5-in 1 Stiff Painters Tool, American Craftsman, 10971 https://www.amazon.com/dp/B017PFD8OM/ref=cm_sw_r_cp_api_i_SieDCb6X10FRR
I tried a putty knife but it flexed too much to get it to pop.
Moderator
I used an Interior Clip remover like Dennis above.
Moderator
fuzzmanmatt
I've got a broken handle under that stupid arm, maybe I'll mess around with doing this while I have the thing off. That's good info to have!
Plati
2014EL
Ordered the AUTOBOO arm & blade for $16.66 (no tax or shipping) from the Evil Amazon
Needed arm because the "nut cover" had vanished & where the blade clips in … was broken
Just got it (order Saturday), took old one off with battery terminal puller & 1/2" wrench
Put new one on with a dab of blue Loctite … tightened it until I felt it was really tight
New "nut cover" snapped right on. Quality is great!
Easy Peasy
wiper-arm-removal-tool-autozone-car-wiper-arm-puller-battery-terminal-bearing-removal-tool.jpg
Moderator
2014EL
Easy Peasy
Why go with OEM style and not a real arm like the doorman that can run any wiper blade?
Plati
6 of one, 1/2 dozen of the other …. (ie sort of the same thing)
no big deal either way, either solution works just fine
the retrofit with a traditional blade mount is a nice idea though
i'm not against it or anything like that
going OEM design was cheaper …. $16 vs $27 ($11 available to buy BEER)
and I can just order the oem part in the future when I need a blade
auto parts shops carry the Trico 16-J for $12 or so
and it wont confuse any repair shop when i'm old and take it in for service (3 years from now)
when my Expy is a 50 year old Classic Truck
it will be 100% stock ... leading to higher sell price on Barrett-Jackson
this oem design will probably break and i'll tire of it and do the retrofit in a couple years!
Moderator
To each his own. The OEM design is terrible. So the Doorman was a no brainer. Not to mention being able to run a good aftermarket wiper. Cost was not factored in for me. Better function is always what I am looking for.
Plati
I've never had any issues with rear wiper function.
Replacing it is easy … once you know how.
I've heard people say the design is bad, but never really understood the issues.
That bushing going through the glass that buggers up and drains the battery
now THATS an issue
