Amazon says this will not fit my 2010. Are you pretty sure it does?
Will definitely fit.
Hey guys,
My factory arm is sagging down off the glass. I wasn't able to get it off to replace or realign. Was afraid to break the glass. If it is wedged on should I try a gear puller or something?
Thanks,
CV
Spray the shaft with some WD-40 let it sit for a little bit.
Take a painters tool, A putty knife is too thin and flexible, slide between the arm base and the plastic area around the shaft area and wiggle it.
The arm will pop off and be pretty loud.
Warner ProGrip 5-in 1 Stiff Painters Tool, American Craftsman, 10971 https://www.amazon.com/dp/B017PFD8OM/ref=cm_sw_r_cp_api_i_SieDCb6X10FRR
I tried a putty knife but it flexed too much to get it to pop.
