Can you tell if Expy has tow package based off VIN?
CaptOchs
Rochester NY
Looking to buy a 2017 or 2018. I need the tow package because I have a 7000# camper. I looked at one the dealer claims has a tow package because it has a hitch. It only had a 4 pin connector. Can I tell if it has the factory tow package based off VIN?
ManUpOrShutUp
For 2017 the "Class IV trailer tow receiver with 4-pin connector" is standard on the XLT. The "Heavy-Duty Trailer Tow Package" is standard on the Limited, King Ranch, and Platinum and it will have 4-pin and 7-pin connectors. No 7-pin connector means no HD trailer tow package.
shane_th_ee
Seattle
They all have a “tow package”, but you need one with the “heavy duty tow package”. Note also that for 2018 and 2019, all of them come with the 7 pin connector. For 2018/19, you can almost always spot the heavy duty towing package from the pictures: look for the trailer backup assist button/knob...
C
CaptOchs
Rochester NY
So most if not all of the XLT's don't have the HD tow? If so, that could be my problem. I haven't looked into other trims because I was trying to keep cost down.
C
CaptOchs
Rochester NY
So if all 2018/2019s' have the 7-pin, I can't use that to determine if its HD tow or not. I guess I'll have to look for that button.
C
CaptOchs
Rochester NY
All good info. I'm trying to decide if I should buy this year or next. My budget is around $25-$30k. My 2003 is still running well with 157k. I drive it most days to work. Right now the 2017's are in budget. If I wait 6 months to a year the 2018's will come down. The 2018's look to have a slightly better engine specs and the 10-speed transmission. My trailer is a Keystone Springdale 270le. It's almost 33ft long. I would think the 10-speed transmission would do better towing. Sometimes my 5.4 is hunting for gears at expressway speeds.
Trainmaster
Old School Member
Rockaway Beach, NY
The HD tow package is available on the XLT's; but it's an added option. Look for the 7-pin connector or the oil cooler behind the grille.
ManUpOrShutUp
As Trainmaster said, it's optional. The other aforementioned trims for that model year will always have it. The XLTs may or may not.
rdlangston13
Katy, TX
I believe if it has the max tow package it will have the 7 pin connector and trailer brake controller. They all have a receiver.
Eagle 71
Nebraska
Capt, try an online service called CompNine (www.compnine.com). If your VIN is available in their database, the four-page report will provide a code and associated description of every option that was installed on your vehicle when it left the assembly line. There is a disclaimer on their webpage that says they only have VIN data for Fords up to 2012, but I was able to insert my 2013’s VIN and it worked fine. Anyway, you can enter your VIN at their homepage to see first if they have a report for your Expy; if they do, it costs $5 for five VIN checks. It’s legit – it worked for me last Oct, and answered/confirmed a lot of option questions before I purchased the vehicle. Worth the five bucks.
The report I purchased for my VIN showed that my Expy came with the heavy duty trailer towing pkg, trailer sway control, and a heavy duty aux trans oil cooler.
Associated point: If the vehicle still has a window sticker, all the info you're looking for will be there too.
obonaven
Southern NJ
Don't rely on the plug. I don't have a tow package but I have the 7 pin/4 pin plug. I added it after I purchased it. But if you only have a 4 pin plug I'd say it does not have a HD tow package.
C
CaptOchs
Rochester NY
I test drove a 2017 limited over the weekend. It was $26k and had like 67k miles. It had all the options, but I don't think it handled nearly as nice as the 2003 I have. IDK how to describe it exactly. On the scale between truck and car it handled more car-like? Maybe it's just because I have great tires. Not to offend anyone! Maybe the 2018 would handle differently. I might just hold off. My Expedition is still going strong.
mquick5
Buckeye Country
Sounds like a killer deal on that 2017 limited!
On a side note my Uncles 2017 F150 he purchased used, had the factory trans cooler. But not hitch or connector at all!
Elocwem
Largo, FL
While shopping for my used '17 XLT, I too wanted to be sure it had the HD tow package.
If there is a factory brake controller on the dash, the HD is there. You can verify with the 7pin & trans cooler.
But as far as the XLT-- you only get the brake controller if the HD package was installed.
johnboneske
I also have a 2003 5.4 pulling my Keystone outback 293UBH, which has a GVWR of 7600, and would say I am around 7000. How does your 03 do? I feel like mine doesn't have enough oomph/power. It handles great with my Equalizer hitch and prodigy Brake controller, but feels under powered. Maybe I don't push it hard enough? Your thoughts?
C
CaptOchs
Rochester NY
Hey John. You PM'ed me last December. I don't think the 5.4 lacks power necessarily. It does take a bit for the transmission to get dialed in. I find with overdrive on, it does bog down on hills with this much weight. I just turn it on and off depending on the hills. If I find it shifting a lot like on a long uphill road, I just keep it off for a while. Once I get over 62 MPH it doesn't quite bog down as much and I leave OD on. If you think your truck is not performing well, it be something mechanical like plugged cats. I replaced my entire exhaust a couple years ago.
Jeff Taylor
Smyrna, TN
CaptOchs and johnboneske, how many miles do you have on your 03's? I have an '04 Eddie Bauer with 220,000 miles. Original engine, rebuilt transmission. I have the HD towing package. I've been towing a pop up for years and also a 6x12 enclosed trailer. I've never had any trouble and in most cases, my Expy rolls along like the trailer isn't even there.
I'm considering a new camper. It's 33' and has a 7,800 GVWR. According to everything I'm reading mathematically I shouldn't have any trouble, but it's a big jump in weight, so I'm nervous. What are your thoughts? Both of you seem to be hauling similar sized trailers. I'd love your feedback.
C
CaptOchs
Rochester NY
Whoa. A popup to a 33 ft'er? Nice. On paper your truck tows 8600-8900 lbs. It will tow that camper, but realistically you will be limited. Because of its age/mileage towing close to weight limit will beat the truck up. You also would need to limit trips to a reasonable distance. I stayed within 200 miles. I avoided crazy hills and didn't push it over 65 MPH. You also need a capable WD kit. Prepare to spend an extra $500 on a good one at the RV dealer. As a good rule of thumb size the trailer to 70% of your tow capacity. So for you that equates to around 6200 lbs. You can tow more, but you have to stick to limits and get creative. We took two cars. I packed my wife's minivan full of stuff so I wouldn't have put as much in the trailer.
The 03 Exp I had had 160k on it with original engine/transmission. My trailer is 2018 Springdale 270LE that weighs 7000lbs. The truck was pretty rusty due to WNY salt. I got by towing the Springdale, but I did have more repairs. I also realized the chance of a breakdown is higher and no one in my family has anything that could tow my camper home. For that reason I decided to replace it. Last month I bought a RAM 1500 with a 5.7 HEMI. It was a world of difference. I have a 10,000 lb tow capacity which puts my trailer at 70%. If I kept my old 5000 lb Keystone Hornet camper, I might still have my Expedition.
Bottom line: your Exp will tow that camper in short term, but I'd start saving for the next truck. I gave my Exp to my brother in law. He said he replaced the fuel filter and the engine seems to have more power and runs smoother.
http://www.trailerlife.com/wp-content/uploads/2012/01/Trailer-Life-Towing-Guide-2004.pdf
