Remove Middle Row Middle Seat
PaulthePaul
Has anyone tried to remove the middle seat in the second row? In the old (2017) Expeditions you could easily remove the middle seat. I am looking at a used 2018 and I like everything about it but it has bench seating, not buckets. I don't really need the arm rests so not concerned about that. I took a look and figured it was just bolts. But there is a wire harness hooked up to that seat.
Sgt Darkness
East Tennessee
Yep the wiring harness is for the heated seat, seatbelt, and for the motor that works to lay middle row down flat. If you want to use buckets in second row just reattach the wires (if buckets are the same as a Limited) and you're ready to go. Good luck!!
jboji
Detroit
Did you ever remove the middle seat from the 2nd row? I am looking to do the same.
Thx!
Staff online
zeroday
