2003 Expy XLT: Rear sway bar bushing bracket/holder bolts spin.
Cooper
virginia
I've been trying to change my sway bar but, when I try to remove the bracket the holds the bushing the bolt just spins.
I can see the head of one bolt and its prefect flat on top. The other is inaccessible due to being inside the frame.
Don't wantto just cut them off as I would no be able to replace them.
Anyone ever changed out a rear sway bar and bushings on a 2003 Ford Expedition XLT 5.4l?
If so any advise would be greatly appreciated.
PS I don't have any air tools.
Hamfisted
Ft Lauderdale
Is there a lot of rust in the area of the mounts ? Spray on some Liquid Wrench (Walmart) and let it soak for a few minutes. Can you get a pair of ViseGrips on the end of the stud without mangling it ? To hold it while you turn the nut. I replaced mine but it's been a long time. I installed a Belltech swaybar.
Bain64
Do the end of the bolts have a hex head on it? It looks like you could put a box wrench on the nut, and a socket or wrench on the end of the bolt to prevent the bolt from turning. Otherwise soak it with a penetrant and try an impact wrench. I too upgraded to a Belltech, replacing the whole sway bar, and don't remember having trouble despite the copious rust under my 2003.
Cooper
Cooper
virginia
Thank you for the relpies guys.
How I did it was use a hand grinder and kntched out slits on the bottom of the bolt.
Then used a flat head screw driver to keep it from turning.
I went to NAPA for replacement bolts but none are available so, I just clean the treads and reused them.
The new issue is there is sometimes a light knock or clunk when going only bumps at slow speeds.
I think I need to tighten everything again with the wheels on the ground?
BTW these are the parts added all from Amazon and a comparison pic.
Stabilizer Sway Bar Link Rear LH or RH for 03-06 Expedition Navigator Truck SUV
Belltech 5550 Rear Anti-Swaybar
Cooper
Cooper
virginia
No the are smooth.
Cooper
Cooper
virginia
Dog it! Looking at you pic I see that I put the part that bows in the up position. God I got to fight with them bolts again. THis time with lock tight on them :(
Hamfisted
Ft Lauderdale
Yeah, I don't know, I thought it could only go on one way, but it's been a long time since I did the install.
Cooper
Cooper
virginia
Got some impaact sockets and used my hex impact drill and wow it made a huge difference. Zips those nuts out like nothing,
Truck stays so flat when cornering now. I love it!
