mquick5
Buckeye Country
Seriously! I mean come on it's not like it would have broken unless straight up carelessness. Good thing is I can return it to Advance Auto Parts which is like a 10 minute drive from me.
Sent from my SM-G935V using Tapatalk
That's what I had to do with mine. I had them ship to store, so I could pick it up there and inspect it before leaving.
NRose
Oregon
Installed the drillless mud flaps by Duraflap. It was so easy, and they really protect and look great.
RenegadeBad_Dog
South Carolina
So ups dropped off the new rock guard today. My stomach dropped when I saw the box was nearly ripped in half luckily the rock guard appears to be a okay. Should get around to installing it Saturday!
scoot0073
Georgia
Installed 2 new front brake calipers and new pads. The driver side locked up on me so figured might as well replace both.d5bdc6105d6d0efdd8ca177f43fe64a0.jpg5f0f930c4a83715ac309179293db350b.jpg
sjwelds
Kansas
Had it serviced at my local Ford dealership.
Rotated the tires myself. Torqued lugs to 150 ft-lbs. Used the x-pattern rotation.
EightIsEnough
West Virginia
Replaced plugs and COPs @123,500 miles on my 2010. I had the dealer do my 2006 because of the plug's reputation for breaking. These were a cinch.
I also changed the oil. I used 5w-30 on FordTechMakuloco's recommendation. I was having trouble with the engine stumbling when I needed to pass, and the plug/cop change fixed that.
I used all Motorcraft parts. I would like to keep this one for awhile. Now way I could replace it for what I have left to pay on it.
I am hearing a whine from the engine now, so I will eventually need to correct that. I also need to replace a blend door actuator in the rear and fix the front windshield wiper connector. Only one is working. Lastly I plan to flush and change the coolant. Hopefully that gets me,past the 100,000 mile service issues.
Sent from my VS988 using Tapatalk
Dennis_H
DFW, TX
I got to drop mine off at the mechanic this morning. Started it up, let it idle for 45 sec or so since it was about 25 degrees out. Put it in reverse and touched the steering wheel and heard a pop. Said 'What was that?' As I tried to move the steering wheel, I knew... Hose busted, power steering fluid all over driveway and engine compartment. I did drop it off at my mechanic since it is too cold to work on it outside. We'll see how bad later today...
Dennis_H
DFW, TX
Well, it wasn't a busted hose. The OEM crimp clamp on the hose had come loose and the hose came off. It was the one from the rack and pinion to the cooler. Mechanic put on a new clamp and cleaned it up as much as possible, but it still has some fluid in hidden spots that are dripping. Hopefully they will all be gone in a day or so. Doesn't seem to be the hose, but I'll watch for a few days.
scoot0073
Georgia
Well got my hood latches installed today.
Only got to make the final adjustments for the hight I'll do that tomorrow.fca1aa846a87bf68975c4948b9845f23.jpgeb67119932e03a7fb9d52b7a26dfe507.jpgbf58078c7b84f314dd385ec5ba70797a.jpgead728794f9f230ed61a6b1f7b334e9a.jpg
Sent from my ONEPLUS A6013 using Tapatalk
ManUpOrShutUp
Rental a small Uhaul trailer today and hauled a bunch of large mirrors that I purchased from a gym that recently went out of business.
Plati
Putting them in the bedroom? The ceiling?
Wait, I don't want to know :devilfinger:
added later ...
when I moved into my house it had full mirror on 2 opposing walls in the bedroom, funky
at my advanced age I'm looking into putting a tv on the ceiling directly above bed
just lay in bed flat, look straight UP to watch tv. i'm obviously LAZY
ManUpOrShutUp
I wouldn't be opposed to that. :D They're actually for the home gym though. Going to flip a few to reduce my cost and the rest will go in the gym.
ManUpOrShutUp
Topped off the oil and spent about 30 minutes giving the battery posts/terminals a good cleaning.
Exhaust manifold is slowly getting noisier on mine on cold starts. Time to have it tackled, almost though I was losing a camphaser today until I realized the tick went away after a few minutes of run time.
GaryH2
SE PA
Reattached the front license plate holder with a couple of zip ties and a screw where I could reach. It looks better than the 3 holes and rub marks on the bumper cover.
Sent from my moto z3 using Tapatalk
Plati
Drove it under the New River Gorge bridge
RenegadeBad_Dog
South Carolina
Driving down the interstate in the Pouring rain when the tire pressure light comes on. Luckily I was near an exit so I pull into a gas station to check the tires and see what psi they were at figured it was because of the sudden cold weather but to my surprise there is no way of finding out what your psi is unless you have a manual gauge or bring it to a tire pump. Unless I am blind and could find it in the trucks information display. Needless to say all 4 tires need 10 psi or more in them.
Sent from my SM-G973U using Tapatalk
