Brake Rotors
CyberVinnie
Pittsburgh
i have come to accept that I will inevitably warp the rotors on any Ford vehicle I own, and it’s taken less than 20k miles on my ‘17 Expy EL to prove me right. I also accept that it is likely a result, at least in part, of my driving style as well as my propensity to get my car washed when the brakes are at operating temperature. Beyond that, I blame the rest on crappy steel (as my mechanic once put it to me) and perhaps overzealous newbies at the dealership who go a little overboard with the air gun when rotating my tires.
Anyway, I’m looking for some recommendations; has anyone put good heavy-duty rotors on an Expy?
I put Motorcraft High Level Surface rotors (whatever that means) on my 07’ and they’ve been good. I used powerstop ceramic pads with them.
HawkX66
Semper Fi!
VA/MA
My recommendation is to take a driving course. No disrespect intended, but I finally changed the rotors at 215k miles on my 07 and that was only because a caliper seized. That was with a lot of towing with a 10k lb. enclosed trailer and going through the mountains between Michigan and Florida. The Appalachians will give any tow vehicle a work out. My F350 diesel I never had to change the rotors on. 100k miles of plowing in Mass. winters.
Crappy steel? Not likely. Ford has some of the beefiest rotors I've ever seen.
I threw a set of rotors on my 07 in December from Advance Auto. No problems for me.
Trainmaster
Old School Member
Rockaway Beach, NY
I had the same problem with my Excursion. The rotors would warp in less than 1,000 miles. I cured that when I bought DBA (Disk Brake Australia) rotors that gave me some 80,000 flawless miles. I matched them with Hawk ceramic pads.
When I got the Expedition, I found that DBA didn't make rotors for them, so I bought Ford Motorcraft, along with Ford pads. Never had a problem with rotors again.
Fords "High Level Service" is supposed to be a lower priced line of parts to compete with the aftermarket. They seem to be just as good as the "factory replacement" and only slightly cheaper.
I will say whatever steel they used on mine is pretty decent. I put them on about 1 year ago and thru winter they still aren’t rusted.
Machete
My Rig. 2000 EB 4x4 5.4L
Illinois
I tried Powerstop, will never buy that crap again. Warped after 10,000 mi. I went back to OEM MC for rotor and pads. They just work well. Next time Ill use MC rotors and try Hawk ceramic pads to see if I get improved stopping. MotorCraft just fits, quiet, and no dust, but not the best at stopping power.
1955moose
Its strikes me as funny, that so many have no problem plunking down $50-70k for their SUVs but won't plunk back down $100.00 for each Ford OEM rotor. I can't tell you the complaints I had to address with customers complaining about squeaking/squealing after a pad change. I almost never heard a peep out of them when I installed Ford/Chevy/Toyota oem pads and rotors. They just work. If you want good stopping power, get a set of Ford Motorsport drilled/slotted rotors, or drill your own. Back in the day, that's what you did, sort of a roll your own. Course not everyone had a drill press, and a milling machine, but I knew a guy!
Plati
Some might think that they can warp rotors by "driving hard and getting them hot" then quenching with water (rain, car wash, etc). Science doesn't support that though. The metal would need to get 4 or 5 times hotter than you can do by driving for that to happen.
Its science though. Metallurgy
Not everyone believes in science.
I hate cheapass junk pads
Probably chinese
TobyU
Here's what I've found on taking care of any rotors if you care.
Avoid getting them wet when hot. That can warp them quickly.
After braking especially hard but even at stop lights if they are hot....don't sit with foot on brake in one place on rotor.
Either shift to park and let foot off brake pedal or let it roll 6 inches every few seconds.
1955moose
Other thing I heard years back, don't know if true, but don't apply e brake when rotors/shoes are hot. Like after a 20-50 mile drive. Makes sense I guess, applying anything hot metal to friction material, can't be good. Heat in pretty much anything is the enemy. Even with pads, you only want so much heat between pads and rotors, after that point, it's fading time, and oh crap, I can't stop. That will make your sphincter pucker! Pushing down on that pedal, heading towards that 18 wheeler!
TobyU
Except for the many that have the ebrake small shoes in the middle.
1955moose
Yeah but that's why they stick. The hat parts spinning with the rotor. Then when you push down on the ebrake pedal, when the drum is hot, the shoes stick. I rarely use my ebrake, unless I park on a hill. The hat in rotor ebrake doesn't work real well. On top of that, the shoes are a pain to change. Their not like your normal Bendix type shoes on most 90's and older rear shoe type brakes.
jeff kushner
North of Annapolis
Mr stik makes a good point....the rotors today are ventilated and yes they get quite warm but most of us feel pulsating in the wheel and we call it "Warped rotors". To me, it's just a sign I need to open things up....not a diagnosis. When I raced bikes taking a bike/rider wt of 494lbs(on a good day) from 170-180 to 40 in a couple of hundred feet, I would swear I saw red but driving my lumbering truck at 70-80 ain't going to do it.....
I will go with OEM rotors & Ceramics. I've used ceramics for years on my SLK b/c they stop very well, don't behave differently in the rain and they don't leave brake dust all over my alum rims. I
jeff
