Where to start with rotten rockers
SEPTIC PROFESSOR
SARASOTA
next time, go on auto trader, restrict search to Florida Gulf Coast, and buy a spectacular absolutely
rust free 03-04 loaded for around $4K. used to live in the Midwest, no more rusted out junk for me
ever. My 03 is absolutely rust free and the original paint still perfect with zero clearcoat peeling.
B
Bolt snapper
Illinois
Now you tell me! :33:
rjdelp7
2000 XLT
NY
I Spent $1400 at a local body shop in 2013. The rockers are part of rear quarters and body structure. Replacing is very complicated and expensive($3000+, a 'southern vehicle" would be cheaper). I used slip on, patch panels. They bend over the bottom. They are welded and seam sealed. The old/bad rockers are in place, minus the rusty sections. Not perfect, but the truck is still looking good after 5 years. I had the rust stop, oil treatment done. That has really helped.
B
Bolt snapper
Illinois
I've been looking at the slip on panels and wondering how they work around those moulded running boards mine has. It looks like their angle of bend is less acute than what I'd need to get them tucked behind the vertical portion of the running board. I'm guessing I would want to attach them along the top with sheet metal screws? Will the door seals get chewed up if I just left the screws there? Or do I need to drill holes and spot weld and then remove the screws?
Habbibie
Is it Christmas yet?
Chicago
IMHO ... from my own Rustbucket ... Just Let it Be
no probs! no worries! Its waterproof (for now & several years)
Spray some Fluid Film on the rust if it makes you feel better
Consider it a badge of honor, better gas mileage, efficient use of funds, Mad Max, Rat Patrol, milk it for all its worth, etc.
See that hole on the right?
Thats the problem RIGHT THERE
I'm plugging mine up this weekend on my 2014 EL
(the taco salad thing was very funny, good one)
Damn bro yours looks like a disaster lol. Mine looked more like a happy medium between you and bolt snapper's rockers, I had mine prepainted leaving a 1/4" of the edges unpainted so I can get a good weld on them after installation but I'm not sure that was the best option, I rattle canned the rest once I was finished but it left it very sand paper like... i highly doubt anyone will ever notice it but just me knowing it's there irks me lol, it is a far more cheaper option than dropping off the entire truck for a rocker respray that's why I did it... that and I had initially planned to do far more repairs that day which I did such as the notorious "radiator support"
B
Bolt snapper
Illinois
I'm sure I'll be starting a new thread at some point to ask you about this. Mine look disastrous just from a quick visual underneath. I hope there's a similar half-@$$ repair for this, short of replacing that whole front clip!
As far as the rockers go: I took a grinder and cut away everything beneath where the door seal hits (by that I mean the weatherstrip on the door - not the one that is on the cab side that seals to the door) . I wirebrushed the best I could (a pretty pitiful job, since I only have about a 2-1/4" window to reach in there, and those running boards limit the angle of access) and sprayed two coats of a rust converter in there. Then tonight, I sprayed two more coats of black paint. I'm debating now whether to buy these slip on covers or try to have some local shop just bend up an L-shaped (not 90-degree -- I'll have to figure out the angle) piece with about a 5/8" horizontal leg and whatever the distance is to tuck behind the running boards. Those pre-made slip-ons look like I'd be cutting off the entirety of the "door thresholds" and maybe trimming the bottom, as well.
Anyone make their own in this manner?
mjp2
Howell, NJ
Dumb question, what is fluid film?
I was reading through some older threads and it always bothers me when I see something end with a simple unanswered question.
https://www.fluid-film.com/
It's a lanolin-based coating that you put on metal to keep it from rusting or sticking. Works well and has a lot of versatility. Besides using it on my trucks, I coat the inside of my snow blower with it at the start of the season and never have any issues with clogging.
James McCracken
Tennessee
To begin, let me say that I have zero body work experience.
I recently purchased an '04 Eddie Bauer 'midwest special' with rocker panels that are half gone. At this point, the threshold portion is fairly intact, but as it makes the bend to go past vertical downward back under the car, the rust has overtaken the length of both rockers, such that you could literally poke holes all along with your finger, or at least without much more effort than that.
I have looked at the slip on covers, and will probably tackle that in the coming months. In the mean time, in order to slow or stop the progression of rust, I'm wondering if it would be of any advantage to take a grinder and cut out the super rusty side of these rockers and try to apply some primer? Would doing so slow the rust any, or would it hasten the deterioration by removing what little bit of support the rusty portions still give?
I'm kind of looking for a starting point. I hate walking out to the car every day and seeing the little pieces of rust hanging out below the doors and staining the running boards.
I just bought an 04 with the same issue. New rockers are about $150 each. Personally I would not waste my money with the slip on rockers. Buy once cry once and get it done right. One of mine is shot and the other can most likely be repaired.
