Fluid temperature specs
bobmbx
I'm setting up dashboards on OBDLink (MX+), and need some help with fluid temp specs to set up "ranges" on my display gages.
Can someone direct me to the specs for the tranny, coolant, and oil temps? (cold, normal, caution, hot, etc)
Also, which PID does the Expy use to set the the "Oil Temp" indication in the left MFD. I know there isn't an oil temp sensor, but its coming from somewhere.
JimmyM
Boston, MA
I use Torque Pro and a cheapie ELM327 Bluetooth adapter. I have a 2011 with the 5.4L.
For ranges I use 100-250 for all temperatures. I have an actual reading for Oil temperature from a custom module I built.
But I don't have ranges for temperatures.
But 185-205F is normal range I see for Coolant. So maybe 210 - 235 for the yellow range, above would be red.
Transmission rarely sees over 210F when towing slowly up hill , So maybe 210-235 for yellow, above would be red.
I am just recently able to read actual oil temperature. But It climbs slowly and only ever hit 200F briefly while towing up hill in about 50F ambient. I've read, however, that the EB3.5 is harder, thermally, on the oil than the 5.4L
mjp2
Howell, NJ
<threadjack>
Do you happen to have a write-up or reference for that oil temp setup? Any chance you're also pulling actual oil pressure readings too?
</threadjack>
JimmyM
Boston, MA
JimmyM
Boston, MA
That chart is a bit misleading. My transmission has 128k on it and it runs routinely at 195F. The internal thermal bypass doesn't even open until 175F.
Older transmissions were less temperature tolerant than new ones.
coolzzy
Idaho
That temp chart needs to go away, modern synthetic transmission fluid is designed to run at 200-205 at normal operating temperature. All Ford 6 speed transmissions will operate at or around 200 at all times, even pulling a trailer. Mine sits at 203-205 towing my travel trailer down the highway in 95+ degree heat at 70mph. I've seen it briefly as high as 210 climbing steep mountain roads with the trailer in tow at 45mph in the heat of summer and the cool spring weather as well. Keep in mind these transmissions are thermostatically controlled, and DO NOT let fluid into the cooler until around 195 degrees.
JimmyM
Boston, MA
I'd love one too, but good luck getting a manufacturer to publish anything that's actually meaningful.
That chart has been around for 30+ years. I remember seeing it when I was a kid at NAPA with my dad.
JimmyM
Boston, MA
Towed about 160 miles and back for a camping trip. mid 70s ambient. Trans temp hit 205 briefly, Oil temp hit 212 for a little while as well.
B
bobmbx
Where are you getting the oil temp from?
JimmyM
Boston, MA
I built a module that lets me read it off the CAN Bus using Torque Pro.
I mounted temperature and pressure sensors at the oil filter. Look further up the thread I have links to it.
jtebbe0529
