JimmyM
So my 3rd Gen (2011) Expedition has an HS-CAN bus that I can use an OBD2-Bluetooth adapter to connect to. I use Torque Pro to display various engine parameters. Temperatures, speed, etc.
However, things like Oil Pressure, Oil temperature are not available to the ECM.
So what if I want to know my Oil pressure or oil temperature, or something else? I'll have to install individual gauges.
But I want to show all of those extra things in Torque Pro.
Our Expeditions have several HS-CAN modules. ECM, TCM, etc. I pull the transmission temperature by using a different OBD2 header to request information from that module. What if I added a new module to the HS-CAN bus? It can gather pressure/temperature data from where ever I want and then those values will be available by using that modules OBD header.
Right?
1/8" NPT pressure sensors are cheap and output 0-5V for pressure, temperature senders are cheap and use 1 wire. These signals are easily acquirable. A few sensors and I could monitor oil temperature and pressure. A remote filter could easily be monitored for differential pressure by calculating the in and out pressure difference. Etc.
I've ordered some parts and will start fiddling around when they arrive.
Thoughts?
Right?
Thoughts?
