Well, ok. I learned something, although I'm not sure what. I guess when I do brakes I take the (caliper bracket, caliper mount, or web) off and the caliper comes off with it. That way I can get right to the rotor and have all those rusty parts in hand so I can clean them up real nice. Like I said, I'm not much of a mechanic and never learned from anyone just got tools and figured out how to get the job done ... maybe not the right way!
Either way ... my original point was maybe the problem with one pad wearing and the other side not wearing was slider sticking, not greased. Just trying to save you the cost of a caliper or two and fix the root cause.
You take the 18mm caliper bracket bolts off and take the whole bracket and caliper off together?? That might not even be possible of some cars but it's a quite a bit harder if you are just changing pads. Those bracket bolts are usually really on there and take a nice size breaker bar to pop loose. Then its just heavier and more cumbersome. and if you take it off to go any more to clean you would have to remove hose from caliper and I only do that if I am replacing or rebuilding caliper or replacing hose.
Try just taking the two 12 or 13 mm bolts out and pressing the pad in a little and taking caliper off.
But wait. If you take bracket off with caliper you can't gets pads without separating caliper and bracket...OR CAN YOU. I think they will pop out the inside. But some have the curved fatter end of the anti rattle springs/clips on inside. HMMM
Inquiring minds want to know. TIME LIFE BOOKS presents...Mysteries of Driveway.
Order now- only 3 easy payments of 8.95+shipping and handling .
