Show your Lifted 3rd Gens
16plati
VA
If you buy f150 5100s, stock or second height mark for FRONTS gets you around 2-2.5”. Expedition 5100s I would just go all the way
If you are gonna do rears, you need to buy either the expedition 5100s or f150 4600s and put a strut spacer on it
San Diego
I went to the 3rd setting for the front it gave me 1" and to the 3rd setting for the rear it gave me 0.7" . I still think it's a little higher from the rear. Thinking of going down to the 2nd setting for the rear 0.4" to see if it will level it...b836db2f5b4633086364a8fcc7981ccb.jpg44f15ef8303c7dc9e5cc88eabc69aa5e.jpg
Sent from my SM-G975U using Tapatalk
LRNAD90
God dang the lift definitely pulls those rear tires forward. They are no where near centered
Its a pretty well documented side effect of lifting 3rd Gens, not sure there is really an answer other than staying stock. Still seems to me it would be a relatively simple option to offer longer control arms for the rear suspension, but whether its a lack of market, or technical issue, no one seems to offer them..
I love the way your EL looks on 35's BTW, and have often wondered how you have enough lift to clear them , yet don't seem to suffer from the rear tire's pulled forward look as much as most lifted Expeditions I see..
View media item 6823
Cy Webit
Southern NJ
Can you share that media with us? I get permission denied
HawkX66
Semper Fi!
VA/MA
Thoroughly bummed right now. I finally took my Expy to work and realized I'm not even going to be able to lift it a 1/4" if I plan on driving it to work again. I park in a secure sub level garage in DC. They all list 6' max clearance, but never an a real issue with my 07. I would scrape slightly on two pipes on my cross rails. My 17 is exactly the same height because it does exactly the same thing. Maybe I'll bag it lol
LRNAD90
I'm confused, did you expect your '17 to be significantly lower than the '07 for some reason?
HawkX66
Semper Fi!
VA/MA
Not at all. It was actually supposed to be slightly higher. I was only commenting because driving to work reminded me that I wasn't going to be able to lift my Expy if I planned on driving it to work ever.
Penumbra
Everywhere, USA
Just remove your rails on the roof until you need them.
