Why on earth are you doing this if you have no idea what you’re doing?Does anyone know how to properly change a shift solenoid in a 6R75 transmission? Do I need to remove the valve body and then take off the black plastic piece?
View attachment 30965 View attachment 30966
I’m seeing if anyone has done this before to see if it’s something I do myself or a mechanic.Why on earth are you doing this if you have no idea what you’re doing?
Oh boy, I wish you luck. You’re a brave manI’m seeing if anyone has done this before to see if it’s something I do myself or a mechanic.
My 6R75 decided to stop locking up the TC and is now throwing a wrench on the dash and a P0741 (TC clutch stuck off). My mechanic is thinking it is rebuild time.....this kind of stinks it shifts fine....
I see I can get a 6R75 out of a totaled out expy for under a grand from keystone crash parts/ LKQ with 80k miles on it......not sure I want to sink thousands into an ‘07 so that may be a better route than a rebuilt unit. They also warranty the used part if it defective. Further diagnosis will be performed later but it’s not looking favorable for this trans.
When coming to a stop (10 down to 5 MPH) the transmission jerks. After doing research, a bad shift solenoid can cause that.I was told my vehicle will not pass NYS inspection with this code when it comes due, they cannot pass it for smog test with wrench and P0741 since it slightly reduces fuel economy....thanks NY!
I would have thought it would present more odd traits with this code when I got it read. Really the only symptom I have is the RPM’s are slightly higher at highway speeds, other than that it drives normal. Shifts smooth and solid thru all gears with no slipping or noises. I’ve never heard of a 6R75 failing with 140k on it..... Ive also been told the transmission shops won’t just replace a TC and will refuse to do anything but a complete overhaul.
OP, how did you determine you had an issue with a shift solenoid? It’s odd to me there isn’t much online for such a common trans.
