OIL PAN DRAIN PLUG
Kelvin Pratt
texas
Hello, just got a 2019 Limited Expedition. we love the vehicle so far but i'm concerned about the oil pan drain plug I keep hearing about. Does anyone know if my expedition has a plastic or Aluminum drain plug? I always do my own oil changes. And can anyone recommend a good set of ramps that wont snag the front bumper lip? Thanks to all!
Kmdcolo
My 18’ plastic. There was rumor that late 2018 the switched to metal but this may have been a limited production change. Look underneath for the yellow drain plug found on the plastic pans. It will be under the second skid plate on the passenger side.
There was another post on this forum recently about the plastic composite oil pan and plug vs metal. At some point, Ford stopped using the plastic pan and changed to metal on the 4th generation Expeditions. Do a search.
Deadman
April of 2018 they trashed the plastic oil pans and that crappy drain plug. They went back to aluminum oil pans.
Overtow
CLEVELAND
My build date is 7/21/18 and the drain plug is metal.
You have to drop a debris shield to get to the drain plug, making what would otherwise be a simple job a pain in the ass.
ProTip: Don't completely remove the passenger rear heat shield screw, just loosen it (after removing the other three. Once loose, just rotate the heat shield out of the way and drain the oil. Once done, rotate it back into position, insert the other three screws, and torque it down.
Did I mention Anti-Seize? I anti-seized the crap out of the screws. I'm in Cleveland and these things are not going to last with the salt exposure we have here...
I'm seriously considering getting something like this so I don't have to drop the shield every time I change the oil:
https://www.amazon.com/Stahlbus-Drain-Valve-M14x1-5x12mm-Steel/dp/B01AMXAVX0/ref=sr_1_1?keywords=Stahlbus+Oil+Drain+Valve+Plug&qid=1564626818&s=gateway&sr=8-1
Tom T
Dallas
Did today my Stahlbus mod. The mod is great but oil change is a mess...not the first who witnessed that, but its a huge mess....stahlbus should make it much easier.
Also, I added the skid plates of the Raptor and FX4....doesnt make it easier either. A total of 7 screws have to be removed, a small insert (of the raptor plate) and a big one in front to access the oil filter....who said that oil change is easy in the 21th century....lol
mikeyanxu
Oregon
Thanks for sharing,
The M14 x 1.5 x 12mm is the correct part to fit on the oil pan? Just wanted to double check.
Thanks,
