tritonman5.4
hey i want more power outta my expo the TBS is next,are they good mods or not??? thanks guies
They only work as paperweights.
im sure they work in some small way at full throttle but i doubt it is noticeable
you cant get horsepower when looking for mpg...its either or...or minimal to both...
Wasting your time and money. Try a Gott mod (Google it) and a good old fashioned performance muffler. More air in plus more air out equals more power.
I believe you can get both depending on the mod. Increasing efficiency will get you both mpg and power. For instance, underdrive pulleys. They remove some parasitic drag, which on the dyno adds about 5-7 hp usually. At the same time the engine doesn't have to work as hard, and mpg will increase slightly.
Another situation could be efficiency with the fuel mixture. The closer you are to a perfect peak fuel mixture, the better the power, and also the better the mpg. On my 350Z the factory had made the high rpm fuel mixture very rich as a safety margin to keep the cylinders cool, and last longer. The biggest thing Technosquare does as part of their computer upgrade is to correct the overly rich mixture, and pick up about 18 hp overall. The mileage also gets better by about 2 mpg.
One last thing lol. I swapped out the stock exhaust on my 350z with a true dual system. After resetting the computer my mpg (at 65mph) went from 29 to 33 average. HP gains for that system are claimed to be 12 hp. Not bad, and I gained power/economy by removing a restriction and being more efficient.
Remember, a tbs helps accelerate incoming air but your MAS limits how much your engine can have period...change out your MAS first, then more metered air can come in and your computer will recognize and compensate for it
