Ford SYNC Update
rs4-380
Maine
does the updates the graphics to what I am seeing on the 2020 cars?
2018ExpyPlatinum
Arizona
I updated my maps last week. Took an hour and I see no difference, at least locally.
I, too, had a notice of a SYNC update on the app. Told me to go to the web, and that says UTD.
Super Moderator
Super Moderator
That is 3.4. Pretty sure this update is to the newest version of 3.3...but waiting for confirmation with a version number.
spiderman865
Chicago Area
It’s the order that matters. The reset, then the 2 reboots.
Curious of the version number to confirm which revision is the troubled one.
Hopefully they fix your other issues!
When you get it back, check the Version. Should be Sync 3 3.X xxxxx... post that and let’s make sure ya’ll are all fighting the same version.
Sync Version 3.0, build 19205
Lee Hartwig
West Chester, PA
I ordered the online version, followed the instructions, could not get it to work, spent the additional $40.00, received the USB, plugged in, worked first try. You MUST leave the engine running for +/- 1 hour for this to download. PITA but worked.
Super Moderator
Super Moderator
That is the Map update, not Sync. Sync updates are basically operating system updates that fix or sometimes add features.
aziz
Kuwait
mine Sync Version 3.0, build 19205 when we will get 3.3 or 3.4 ??
Super Moderator
Super Moderator
When you go to CyanLabs and download the files and follow the instructions.
I personally believe that 3.0 equipped units will never officially go above 3.0.
3.3 can technically go to 3.4 without a format, so vehicles equipped with 3.3 from the factory will probably get an update to 3.4 officially released by Ford.
aziz
Kuwait
I'm gonna wait few month because I'm afraid it will not work with middle east version
