Probably ran his fuel tank below 1/4 tank too many times. All that hot fuel destroyed the seals.
Not very helpfulPushing gas out when running … and cant tell where its coming from?
I was just suggesting to other readers the importance of diagnosis.Not very helpful
Good point. The first leak was the filter, the 2nd leak was caused by me. I cracked the lock tab putting it back together although I didn’t know until today. I should have replaced them to begin with since they felt brittle and I suggest this to anyone changing the filter now. After replacing the filter I ran the engine and drove once and double checked—no leaks. Today it vibrated off because of the failed lock tab and had a BIG leak. Ran to parts store and bought new lock tabs and replaced both. Fixed again for now lol.I was just suggesting to other readers the importance of diagnosis.
Parts swapping is risky. If gas is pouring out you should be able to dry it up, start the engine and see where its coming from. From your description it sounds (I dunno) like the fuel line connector was faulty, not the filter. I've had both the line connector and the filter itself leak on my 2003 and had to be replaced to fix (different events). I was able to diagnose and fix in one shot each time. Not bragging, just a proponent of diagnosis. The Scientific Method. This Forum is about learning things. YMMV
Another diagnosis idea you shared (from tow truck driver) would be to wiggle the fuel line connector with it running and see if that has any effect. Not honk on it , just a little wiggle. I've used that before with wiring connectors. Free tools (your hands & brain).
Fair enough?
