The rear hatch button stopped working. The dash button works, the key fob button works, and the kick sensor works.
Any ideas?
Quickest fix till you can get it into the dealer is press the lift-gate button and then press the ridge to the right of the button. Works every time for me.
It's not what's behind the ridge, it's just that button gets hung up somehow and pressing the ridge releases it. Holding the button is how you set the liftgate max open height; when the button gets hung up, the vehicle thinks you're just trying to set the height not close the gate.That works! Why does it work? What's behind the ridge? So bizzare.
my Kick sensor works, but only the left side. never could get it to read on the right side.In the "plus" category, you are just about the only owner on here who has stated that their kick sensor works.
This is a result of the tow package...not sure if yours is so equipped or not.my Kick sensor works, but only the left side. never could get it to read on the right side.
Haha...mine works like a champ, but I agree I am also an outlier.In the "plus" category, you are just about the only owner on here who has stated that their kick sensor works.
My Navigators favorite car prank it to open the hatch as I’m connecting my trailer... good times.
otherwise, I can get the hatch to open with the foot sensor most of the time, there is a definite art to the process.
yes i have the tow package.This is a result of the tow package...not sure if yours is so equipped or not.
I have the tow package and mine works on both sides (the center doesn't work). Not that it's reliable - I have about a 40% success rate after practicing for almost two years. I'd suspect a failed sensor on your vehicle if you can't get the right side working.yes i have the tow package.
the manual states that with the tow package, there should be TWO sensor locations, on either side of the hitch. only ever got my left side to work, which i'm fine with. I just have an issue when the manual tells me it should do something, or work in some way, and it turns out to be different. If the manual said left side only, than okay, works as designed.
Like the distance indicator feature, my issue wasn't that i needed the feature, but rather that it was indicated in my manual as a feature, but non-existent on my vehicle.
Exact same problem. FollowingThe rear hatch button stopped working. The dash button works, the key fob button works, and the kick sensor works.
Any ideas?
