2001 Expedition Eddie Bowers aftermarket stereo install
Letsrunum
Oklahoma
Do I need this to hook up the factory amp?
https://www.amazon.com/Kicker-KISLOC-2-Channel-Speaker-Converter/dp/B00I4EF1BC
Only one set of RCA's coming out the kenwood cd player for the amp I'm going to install for two 12" subwoofers in the back.
https://www.kenwood.com/usa/car/receiver/kdc-258u/
Wiring harness I bought for factory connectors
https://www.walmart.com/ip/SCOSCHE-...it-for-Car-Radio-Stereo-Installation/10752522
I will be hooking up my old kicker equalizer as well. I found the PDF file on it as well
https://www.kicker.com/03kq5
https://www.google.com/url?sa=t&sou...Vaw1dtP_VWXTTZ8sAMFubCvJR&cshid=1584599282533
I haven't had to this for almost 20yrs so I'm trying to remember where everything hooks again.
L
Letsrunum
Oklahoma
Or can I use the front and rear outputs on the equalizer to run both at the same time?
See if I can find the remote bass control level accessory too for my equalizer.
L
Letsrunum
Oklahoma
See if I can find the remote bass control level accessory too for my equalizer.[/QUOTE]
Using the Remote Bass Level Control in the KQ5:
If you are using a KICKERKX amplifier that has a Remote Bass Level Control jack, the amplifier can be controlled from the KQ5. Just plug the phone cable (supplied with the amplifier) into the back of the KQ5 and plug the other end into the input jack on the amplifier. This eliminates the need to dash mount the Remote Bass Level Control knob. The knob labeled REMOTE now controls the KX amplifier(normally this controls the sub bass level). The RCA output jacks shown below are not available on the KX.3, KX.4 and KX.5 amplifiers. Not all KX amplifiers come with a Remote Bass Level Control. Check with your Authorized KICKER Dealer for availability.
Note:: This control is still compaatible with the RGX module in the ZR amplifiers,, Impulse 405d amplifier,, and the Impulse x33i crossover.
Just plug the phone cable (supplied with the amplifier) into the back of the KQ5 and plug the other end into the input jack on the amplifier. I GOT PLENTY OF THOSE OLD CABLES
The knob labeled REMOTE "will" now be the control bass control knob for my PG amp. Answers that question
L
Letsrunum
Oklahoma
Only one set of RCA's coming out the kenwood cd player going to the equalizer. Use rear output from equalizer to the amp for two 12" subwoofers in the back.
Specs and the PDF file on the equalizer as well
I haven't had to do this for almost 20yrs so I'm trying to remember where everything hooks up again.
Edited Version
L
Letsrunum
Oklahoma
Bypassed factory amp with my head unit pushing out 50w x 4(probably better than the factory amp).
L
Letsrunum
Oklahoma
Looks like your Kenwood needs an exorcist. Replace any speakers, or still running factory?
Hell Yeah - Demons in the dirt
Just the Mach factory speakers and the two 12" crossover CF3 with Phoenix Gold amp.
Missing my 10" Kicker square comps solo baric L7's and kicker ZR600 amps that went with that equalizer when I bought many years ago. Sold for parts to get my 1972 Cutlass Supreme running again.
L
Letsrunum
Oklahoma
Nobody uses CD's anymore and most aftermarket units come with Apple or Android phone compatibility, WiFi, and dozens of apps and traffic reporting to entertain you. I think the Micro SD card music storage has replaced the CD options.
No way your Mirco SD card is going to store my massive cd collection with lossless audio quality...most of the time people shrink/compress their music files or video files to fit more files on their small storage space(sacrifice quality). I got my collection converted to WMA lossless on 1TB expansion portable drive for my desktop computer. My collection is also mp4 lossless with apple.
Records have the best audio quality sound and can be converted over as well.
L
Letsrunum
Oklahoma
My older kenwood head unit I bought used for $25 is not compatible with my Samsung Galaxy Note 9(added 64gb micro SD card), with roughly 155gb of total space for everything on my phone.
