Tow Hook to Shackle Conversion
Donn Brink
Hood River, Oregon
Anyone find a source ? I would like to convert my front tow hooks to a shackles.
Any suggestions ? Is the F150 or F250 front frame mount the same ?
Thanks !
scottdm
Western PA
The video below showed Rough Country shackles on an F150, but I didn't see it on their website. Maybe worth a call to them to inquire since the mounting points should be similar on the Expedition frame.
Looks like the following might be an option on the F150 as well: https://amistyling.com/demon-brackets-ford-09-19-f150
I've ended up using Gator Jaw soft shackles for the front tow hooks. They take up almost no space when not being used and don't rattle around.
https://www.bubbarope.com/gator-jaws-synthetic-shackles
Saltwater Soul
Houston, TX
I was disappointed to find out my tow "hooks" were in fact tow "rings". I get off road a bit mostly on the beach and always found it useful to be able to string a bridle easily between the hooks when a tug is needed. I have a perfect size strap to fit between them. My old 2500 Suburban had actual hooks. Now it is going to require a bit more hardware or another solution.
joethefordguy
why is that dissapointing?
AKentPhoto
New Orleans
:think: @joethefordguy good question... A couple shackles or a longer strap to double back to a single shackle shouldn't be too bad.
@Donn Brink
Thank you so much for posting this, I had no idea this was a thing. Really hope we can make these work. This could save me a lot of headache.:favorites13:
Saltwater Soul
Houston, TX
Because it is crazy easy to place the loops of a short strap with loops on each end around two hooks to make a bridle. No extra hardware needed. It comes off equally easy. With rings you can't just place a loop around both easily. I feel it is much safer than using any sort of heavy hardware. Have you ever seen what happens when you really load up a tow strap and something breaks loose?
joethefordguy
why no, I have no experience at all, as your rhetorical question correctly implied. You're too smart for me!
AKentPhoto
New Orleans
@Donn Brink Are you going to give them a try? I'd just make sure whoever you order them from take returns.... Let is know if you pull the trigger.
At least you have tow "rings". I think I might have some bit they are covered up. Fingers crossed I can make something work.
Black
Kentucky
F150s and Expedition share the tow hook part number so the RCs and AMI should bolt up without issue.
Only question is if the opening is large enough and does the Expedition bumper stick out further than the F150.
But likely not something a little trimming can’t remedy.
I contacted AMI to see what they say.
wakeboarder
Fort Lauderdale, FL
From what I could tell on parts.ford.com and varsityfordparts.com, I think the standard F150 tow hooks are a different part number than the 2018+ Expeditions. They have a hole drilled parallel to the ground. I think the 2019 F150 Raptor shares the same part with the 2019 Expedition for the black painted ones (7L1Z-17A954-AA).
I think the mounting hole pattern is the same on both sets.
Update: 4/14/2020: I think what I said above is incorrect. I think the 2018-2019 Expeditions share the same tow hook with the 2017-2019 F-150's.
Black
Kentucky
Sorry, did not realize I was in the 4th gen section. I compared parts of a 2016.
Black
Kentucky
Looking forward to seeing if they fit.
I contacted AMI which is a division of ReadyLift and they did not know if theirs would fit but they are made in the USA.
If the RCs fit I’ll eventually order the AMIs. The front loop looks much cleaner on the AMI to RCs pretty crude welds.
Also I am pretty sure all RCs stuff is made in China. If you could verify this for us as well when yours arrive that would be much appreciated.
Lou Hamilton
You could always get a pair of soft shackles to ue with the stock tow hooks. I plan getting some when we are free to travel again.
Can't stomach spending money until I can use something. So I will wait it out. ;)
lbv150
Northeast
Tow loops are better. You use a shackle to the strap and it won't fall off. When off roading, you keep the straps preconnected to the loops...better than diving under the mud to hook them up.
D
Donn Brink
Hood River, Oregon
Bummer.....The F150 RC Shackle mounts do not fit. The bolt pattern is spot on but the Tow hook bracket is too large to fit in the front fascia opening. Even if you were to remove the rubber insert, the bracket still would not fit....Bummer...
Deadman
Start cutting. lol
sjwhiteley
Kentucky
Have you got some quick photographs? how much would you have to trim (or cut)? I've already trimmed a bit off my openings after removing the 'covers'.
Black
Kentucky
How much trimming are we talking??
Don’t feel like trimming send them my way and I’ll test them on the 15-17 models.
