Winch bumpers, rock rails and roof racks
nvycrmn
Springville, IA
jail, did you get it with the tire carrier and stuff like that? what size tire will that thing hold? i just want to be able to mount a winch on the bumper. dont want to use a hitch mount cuz im going to take my 8k winch and put that in the rear and put a 9.5 or even 10k winch on the front.
Jailguard
Pinellas county Fl
It will be holding a 285/70 17 Nitto Terra Grappler. With the spare relocated there should be room to fabricate a mount behind the bumper. I am thinking of adding a second fuel tank in that spot.
panda24619
San Diego
do you know the biggest tire it will hold? cause i need to relocate my spare so i can do some suspension work under there. i want at least a 35 if not a 37.
Jailguard
Pinellas county Fl
Well it took 5 weeks to get it but here it is
http://i102.photobucket.com/albums/m93/jailman_1/IMG_20101026_180622.jpg
http://i102.photobucket.com/albums/m93/jailman_1/IMG_20101026_180703.jpg
http://i102.photobucket.com/albums/m93/jailman_1/IMG_20101026_180638.jpg
the lugs they put on to hold the tire are not lug nuts but regular bolts and metric to boot. 12x 1.75
the tire is a 285-70-17 nitto and there is still plenty of clearance to go taller but if you go wider the rear wiper will need to be removed as it is now mine is pinned in place by the tire.
panda24619
San Diego
but since its slanted it hits the window. thats wht i dont like. i might get it cut the slant and turn it around to make it vertical. that way the tire wont rub on the window and i can still use the rear wiper.
Jailguard
Pinellas county Fl
you can tell them that you don't want it slanted since these are built to order. I didn't realize that it would hit the wiper or I would have made it straight.
panda24619
San Diego
oooo. well send it back. haha to late now. i think ill just order it that way then. and the front ill make my self.
aeorn
Hey Jailguard,
Did you end up doing the second gas tank? That would be very cool to see.
