Federal safety guidelines that didn't think about a passenger that isn't driving being able to use the sync system...
Sent from my moto g(7) using Tapatalk
Never said it made sense...just stating the reason.
No manual dim, but auto dims without issue when the headlights turn on automatically.I've done searches around the internet and on this forum but can't seem to find a solution to an issue since I upgraded from SYNC 3.0 to latest 3.4 from cyanlabs. This is on a 2018 Expedition MAX Limited
I have the following issues with the display brightness and mode:
1. Display doesn't go into night mode when headlights are turned on. Not sure if it will work if light are set to "Auto" until it's dark. (Just upgraded today - just traded in my 2011 Expedition for the 2018 Friday)
2. Even if display is set to Auto, Day, or Night the setting for Brightness is greyed out. Even it's "Info" button is greyed out. So I am unable to change brightness levels. I can switch between day and night manually with no issue.
Any advice would be appreciated. Could this possibly be something that has to be fixed in APIM or APIM needs an update?
And my apologies if this has been covered before.
I'm sure Loki will be in here eventually to post his insight, but did you try doing a Master Reset?I've done searches around the internet and on this forum but can't seem to find a solution to an issue since I upgraded from SYNC 3.0 to latest 3.4 from cyanlabs. This is on a 2018 Expedition MAX Limited
So it looks like I may have answered my own question this AM. I should have been more patient yesterday and waited until night.I've done searches around the internet and on this forum but can't seem to find a solution to an issue since I upgraded from SYNC 3.0 to latest 3.4 from cyanlabs. This is on a 2018 Expedition MAX Limited
Yes. I actually did a Master reset twice. Once after the update and then again when I noticed this "feature." But I think it may be intended behavior? I replied to my own post a few minutes ago.I'm sure Loki will be in here eventually to post his insight, but did you try doing a Master Reset?
Right under 2. Download the update....Where are folks getting 20022? I don't see it at cyanlabs.
Just installed this (on my '18 Raptor) the only language options are English(UK), Espanol, French or Portugues? Where is American English?
I have done 2 hard resets..
