Yeah... 3 pulls in perfect conditions isn't a glowing review, but sounds about right. Are you tuned? If not that will only happen quicker due to the extra boost.
Most factory ICs are painfully under sized. The aftermarket IC on my other car is literally 3x the size of factory and was my first mod along with an intake.
Yeah, on the 4th it was only pulling it a VERY small amount, and did not change 0-60 at all. I am stock now. Tuning coming on Monday for the Expedition.
The ST is running on E50. E50 vs Stock is about the same as far as before I need to cool it down, because the Ethanol evaporative cooling makes up for the heat soak a bit. When I was running a hard 93 tune, timing was being pulled a little at the end of a single 1/4 run. E50, Nope!
The ST’s is undersized and needs a little more air being fed to it too. Working on that.
