Fozzy
Riverton
Pretty straight forward installation the only issue I have is that I couldn't find an ignition fuse in the engine bay that I'm willing to risk blowing; I currently have it plugged in to the rear heated seats/temp controls which only enough is always hot.
I tapped fuse 15. It’s a 15 amp that runs the cruise control, camera and voltage quality control. What ever that is. I only need 2 amps for the Switch-Pros ignition sensing lead. Not sure what you need for the Triggered.
Eddie1965
Culver City
That should be enough, just wanted to play it safe with a fuse that if it were to blow, it wouldn't disable a major function of the vehicle. I'll move it over and give it a shot.
Robert McMillan
US
where'd you get the badge/cover? Id really like to get rid of all that chrome (on the badge)!
Amazon sells some decent ones, there’s a few dudes that custom paint them also but be ready to put out $200-300 for them
Robert McMillan
US
Moderator
How well do these actually adhere? Are there ripples around the edges after you lay the sticker out? I’ve seen issues with these where ppl can’t get the sticker to sit 100% flush since the oval is convex
Just like any other vinyl a little heat goes a long way. Line it up, apply to the center, push side, then top and bottoms, then smooth out best you can. Heat gun on low around the edges in a sweeping motion, or a hair dryer if you don’t have a heat gun. The trick is to hit it lightly. It will pul it tight. Take your time.
I have done my 2015, 2017, 16 Edge, and have a set for my 2020 Explorer, but haven’t applied them yet. When I do, I will take a pic.
AKentPhoto
New Orleans
Thought you would be a RED kind of guy.
Haha, if you are in the industry that's not necessarily a complement. [emoji38] But in all seriousness they do make some killer gear. We are a camera support company so we adapt to anything they want to use. The FX9 (used here) is basically a mini Venice (their $90k cinema camera) and the A7SIII is basically a pocket Venice. 120fps in 4k @10bit 4.2.2 internally and in RAW on an external recorder for under $5k in an mirrorless body with in body stabilization is absolutely insane and game changing. Sony is killing it right now on prosumer video gear.
Sorry to nerd out.... The A7sIII has got us camera nerds buzzing and I just watched the launch video/review for it.
Going_Going_Gone
Phoenix
Aren't you afraid someone will drive into those cameras? I've only driven around in Nola once and a woman in a Honda Civic dozed off and plowed into the rear end of our SuperDuty at a red light.
Lou Hamilton
Craigga542
Kansas
My wife shoots with the a7riv. I’m more excited to see what the a9iii is going to bring to the table, but appears we have different uses for the camera. Sony is killing it overall, IMO.
Robert McMillan
US
Do you notice any difference in ride or mpg? Been thinking about this for a bit.
It’s a piece of plastic, it’s not going to affect ride quality or mpg and anyone who tells you it will is an idiot. I took mine off and only thing I noticed is the trucks looks wayyyy better from the front now
Craigga542
Kansas
Actually, it does affect MPG albeit likely unnoticeable. The air dam or valence affects downforce and coefficient of drag, therefore affecting efficiency or HP required to move the vehicle. Simple research will show that. You can easily find images of air flow, pressure and efficiency of aerodynamics on vehicles for a visual reference.
