1.5 leveling kit and 2/3 lift question
Sunflowergirl
Mars
Yep came across those 16plati. Those are gen3’s. I still haven’t come across a gen 4 specifically stating it has a front level with pics. Are we comparing apples to apples on gen3 and 4 suspension and leveling. First Expedition we’ve owned so seeking real experience and advice.
It ain’t gonna be much different than body styles. 1.5” is 1.5” bro. There aren’t any pics on a gen 4 with just a front spacer bc gen4 owners are smart people and lift all 4 corners, or keep it stock so there $80k SUV doesn’t look like this
sanman28
SW MO
So I’ve looked at almost every post about leveling kits and tire sizes. Still curious if anyone has photos or experience with the ReadyLift 1.5” front spacer level kit. Just picked my wife up a 2020 FX4 XLT. Pretty set on moving from the stock 18” wheels. Going with Mayhem Crossfire 20 x 9.5 with 25mm offset. Debating between Toyo A/T III in 275/60 or 285/55. Not sure which stance I want to go with or if I really need the kit to accomplish fitting either tire. Thoughts?
There are two ways to go....
1. wheel with less offset, more aggressive and larger tire, 1.5 level, and removal of the front air dam and perhaps the running boards too. You could pull off the 4x4 look doing all this, but it will still be low. A passerby would probably not every know it was leveled.
2. 3/2 lift, whatever wheel, 33 or 35 tires, and air dam removed. Now you are getting somewhere.
I have the 3/2 lift and i can say that if it was a 4 or 5 id be ok with that. 3/2 is minimum and i think with only a 1.5 you will wish you had gone bigger. Its still not a very tall SUV and honestly looks stock-ish.
Sunflowergirl
Mars
shit he might as well put 5100s on it at max height. At least then it won’t be squatting, he gets 1.x” of lift, can run a slightly bigger tire, and it’s not a spacer. They seem like a win win in his case. Unless he likes the Carolina squat look ?
Sunflowergirl
Mars
Not looking for the rear squat. Thanks fellas
If you lift the front and not the rear what do you think the back will do?its going to look cheap, but hey there’s a look out there for everyone. Maybe you can be the first to lift just the front of a 4th gen and let us know how it looks
Sean Thayer
Katy Texas
Didn’t think I’d get all the smart ass responses. That’s why I asked a question and if anyone had experience. It’s called a leveling kit... I’d like to confirm if it will indeed level or look off. thanks for all the pointless feedback Sunflower
Sunflowergirl
Mars
Yeah no worries, you’ll get to know me, been around a few years here
sanman28
SW MO
Just outa chits, and b/c im not sure i like them (certainly will paint black if i keep), i removed the running boards tonight. Looks much taller.
nameisbry
