5100s way to go, as long as they are the expedition ones and not the f150 ones. Still on a national backorder I believe. I called 3 days agoAfter some further research on other sites etc. Im going with the billsteins 5100 series and just using the lift they give. Says 1.5 inches..plus I heard they are great riding struts. Found a great deal for all 4 from jackit.com for 534 free ship plus 50 bucks off. Its says they are in stock ...fingers crossed. Ill have my local shop install since I'm not a fan of pressing springs myself.
Still got those 22s?View attachment 37887 View attachment 37888 View attachment 37889
before lift/
After lift/
19’ raptor wheels installed
Looks way better with more tire/less rim. Those are 17" rims, not 19", right?View attachment 37887 View attachment 37888 View attachment 37889
before lift/
After lift/
Yea they are the 17'sLooks way better with more tire/less rim. Those are 17" rims, not 19", right?
So does the group agree that 17s can be mounted on a 2014 EL?Yea they are the 17's
I don't mind "trimming" personally.I'd like to know this also. I have a 2014 EL Limited with the Bilstein 5100s (Expy models, not F150) all around. I have BFG AT 275/55R20 tires on 20x9 Black Rhino Block wheels (5.5 inch offset, +12 Offset).
I'm extremely skeptical that 35s would fit, but I'd like to fit 33s without any rubbing or trimming.
Sent from my SM-G965U using Tapatalk
Good point. I agree, as long as it's plastic. I just don't want to cut metal.I don't mind "trimming" personally.
Me too.Good point. I agree, as long as it's plastic. I just don't want to cut metal.
You and @CommO 33/12.50s should fit. You need 3” up front for 35s to fit on factory offsets and no trimming. I run 3/2 with 35/11.50/20 On factory +44 and they did not require any trimming but we’re super close to needing it. I put 1.25” boras on to push the tires back out of the wheel well and had to move my electric running boards and do some fender plastic trimming. Bilsteins and 33/12.50 on anything from +10 offset your should fitQuestion: If I install the Bilstein 5100s to lift myself 1.5 inches, can I run 35 x 12 x 17 tires? if not, now big ? I'm trying to order they wheels and tires and the tire guy's don't know or won't say. 2014 EL.
Thank you. Do I need 9 inch rims for that width?You and @CommO 33/12.50s should fit. You need 3” up front for 35s to fit on factory offsets and no trimming. I run 3/2 with 35/11.50/20 On factory +44 and they did not require any trimming but we’re super close to needing it. I put 1.25” boras on to push the tires back out of the wheel well and had to move my electric running boards and do some fender plastic trimming. Bilsteins and 33/12.50 on anything from +10 offset your should fit
Oh yeah. 9 minimum for 12.50sThank you. Do I need 9 inch rims for that width?
Should I order wider?Oh yeah. 9 minimum for 12.50s
Thanks, Sunflowergirl!You and @CommO 33/12.50s should fit. You need 3” up front for 35s to fit on factory offsets and no trimming. I run 3/2 with 35/11.50/20 On factory +44 and they did not require any trimming but we’re super close to needing it. I put 1.25” boras on to push the tires back out of the wheel well and had to move my electric running boards and do some fender plastic trimming. Bilsteins and 33/12.50 on anything from +10 offset your should fit
