2020 FORSCAN Info?
Expedition Dave
A Tiny Little Dot in Florida
I have a 2020, want to eliminate several things, especially the double-honk, bambi mode, and is there software that prevents you running with the high-beams on in the daylight too?
A comprehensive list--for 2020s--would be amazing...
bushpilot
Houston, Tx
There are comprehensive lists all over the place....its call a spreadsheet....it lists all of the items that can be changed.
the best way to prevent turning you high beams on during the daylight is to TURN YOUR HEADLIGHTS OFF!
Moderator
The spreadsheet running around should NOT be used for a 2020. The coding for the BCM on the 2020 is COMPLETELY different.
To answer the OP, no sheet is needed for 99% of the changes most people want to make. There are quick drop down options for the 2 modules(BCM, and APIM) where most changes are made. Just use those. I Truly don’t understand while people are stuck on having a sheet. It is MUCH safer and easier to make the changes that way.
bushpilot
Houston, Tx
Agree - I was referencing the spreadsheet only for what some of the possible changes may be.
It seems like a perfect opportunity for @Expedition Dave to create a list....if he thinks its needed (which imo it is not).
In earlier threads (not too long ago) I posted screenshots of the "plain English" interface....showing how easy it is now.
Expedition Dave
Expedition Dave
Thank you Loki.
Bush, maybe my post confused you. I want the ability to turn/leave my highbeams on during the day, under select conditions. Further, I thought FORSCAN you had to manully enter a series of numbers that were known before hand into where the old value number was--hence the need for the list of what number corresponded to what action, where.
Loki, I need to bother you some more. PM inbound--
bushpilot
Houston, Tx
never seen anyone request that before, and ive never see a (old) code to do such a thing on any model.
the list youre referring to is a spread sheet - and its not needed anymore.
Dewey3
I know this thread is a couple months old, but there's so many FORScan threads, it's very hard to keep up. I've looked over all the drop downs and not seeing anything... is there a code to disable the NAV lockout for passenger use on a 2020 XLT?
Moderator
No. Not technically.
You can change your location to Europe, but you lose E911, and the SiriusXM special location based services.
I do not recommend doing it. When my Wife was in an accident in her 2015 Expedition, it called the police for her, even before she knew what was happening. She was OK, but it could have been worse!
Dewey3
Thank you. As for SiriusXM, that's a non-issue as I am not a Siruis fan at all. The wife drives the '18 Continental, and doesn't want to drive the Expy because of is size. That leaves just me and the E911. Off-hand, not having the system make an emergency call for me is not a big thing since I've never had that before anyway. In these days of everyone having cell phones, I don't worry too much about being in a situation where I would need the system to call for me, unless something like a rare event where the road is departed, and even then, it will still depend on the post-crash condition of the vehicle.
Moderator
My wife’s car was totaled and it still made the call. I chose safety over a little convenience. Heck, I just use CarPlay anyway...so the nav issue isn’t an issue.
Nate2020KR
Athens, GA
I have a 2020 King Ranch and can't find where to turn on the numbers above the gauges. Like for coolant temp, trans. Any help would be great awesome.
Mlarv
Eastern TN
I did it to mine a month or so ago. I used the F150 spread sheet to do it. If you don't have it let me know and I will look up the changes.
Moderator
It is in the easy config for the IPC...No sheet needed.
People keep making FORSCAN more complicated than it needs to be. 99% of what people want to change can be found in the easy config. No sheet needed.
Mlarv
Eastern TN
I have never used the easy config. I just went to each module and programed what I wanted it to do. I have had several F150's an Explorer and now a Raptor and Expedition. I will have to look at the easy config and see what is there.
Nate2020KR
Athens, GA
I looked there first believe me. It was not there. So I used the code for the F150 and Super Duty, they were the same and worked.
Moderator
The problem is Ford keeps changing modules midstream. Like in the 2020 Expedition. The BCM is COMPLETELY different coding than the 18/19’s. Trust me. I worked with the FORSCAN engineers to determine and confirm the changes. Ran and tested the Beta changes for them.
This is not my first Rodeo. Using previous coding from other vehicles can get you in trouble.
jfreeman6
Atlanta
Easy Config doesn't work/exist for the 2020/2021 Expedition BdyCM/BCM.
Also, as you've said previously, all of the values are different.
It appears that a new spreadsheet is needed (or new tab on the current spreadsheet) for the 2020s and 2021s. I had to use the 2020 Super Duty Spreadsheet to get my changes to work.
I assume that this will be the same problem again for the 2022s since they have Sync4.
Moderator
Not true. It does. Message support, and they will send you a link to a version that will work.
Moderator
In addition, if you are using coding from the Super Duty without confirmation from FORSCAN you are risking REALLY screwing things up. I hope you are backing up your modules before each change!
