I finished installing warn VR 12-S winch on Expedition 20
Fozzy
Riverton
Wow, very nice! Did it squat the front? How do you get in there to free spool it?
Expedition Dave
A Tiny Little Dot in Florida
Welcome Alhrir! Please tell us what it took to accomplish this, as there are many here seeking this as an option. And please provide more pictures :)
Research shows with synthetic rope, it weighs 55 lbs--but I am interested in suspension compression as well.
Expedition Dave
I really wish he would swing back and report in. One of my interests is how much his springs/shocks compressed from the added weight--b/c I am adding Bilstein 5100 shocks that give 1.5 inches of lift--but if 75 pounds extra on the nose will compress that lift by an inch, I will go with the F150 shocks to raise the nose higher to counter it...
wakeboarder
Fort Lauderdale, FL
You could hang a 35 lb bar bell from each tow hook and it would give you a pretty good idea of the squat.
Suomycasino
Washington
Not to be a smartass, but how much does it compress when you lean and put pressure on the front of the vehicle. Im sure you could easily mimic 75lbs, to get you a rough idea of what you would be looking at.
Expedition Dave
No-offense taken Suomy. Just hard to measure the exact weight, exact measured compression, etc. I will try it today w/75-80 lbs of weight (carefully) with before/after measurements.
sjwhiteley
Kentucky
I have a pusher bar on mine. If I stand on it (ahem, a bit more than 200lbs) I can get the suspension to move maybe 1/4 inch if I jump on it (it is a bit cold this morning, so the suspension juice hasn’t warmed up).
Expedition Dave
My 2020 FX4/HD tow (only options) with 11K miles as measured empty, full tank of gas.
Opened the hood and added exactly 70 pound of dumbells, very carefully over the radiator section straddling the hood latch with wooden spacers to prevent crushing and to spread the weight better.
Suspension compressed almost exactly .25 of an inch, as measure at the bumper.
For any other years, suspension systems/lifts, coil spacers, non-FX4, etc., YMMV...
Expedition Dave
Alhrir, I wish there were more pics lol.
I think there is also an intercooler relocation kit that some have made/bought and considering it is hot all the time there maybe a larger IC might help too.
I wish pulling the nose cone was an easy affair, I'd love to set my amateur engineering brain on this one, maybe try to get some more air to the cooler or add a fan or two...
Did you upgrade the battery?
No members online now.
rockinghranch
