Oil Life - What would you do?
David Schaefer
North Texas
2012 Expedition EL Limited, 92k miles.
We are driving from North Texas to Rhode Island and back soon. The last oil change (Synthetic) was 3900 miles ago . Round trip we are looking at 6K miles. Synthetic is supposed to be good for 10K (Lexus) but only 7.5K for Ford (from my owners manual)
So, what would you do? I'm leaning towards having the oil changed right before the trip just in case.
Thanks!
07navi
Mt.Shasta California
Thanks!
All oil gets contaminated and breaks down, change it yourself before you leave.
Jamo
Lee Center, NY
I'd change it too. I can't believe how easy it is to change the oil and filter on my 2014 EL LTD...
Plati
Do you change it yourself?
If so, do it before trip.
Will you be too busy on trip to get it changed?
Otherwise just change it when it's due.
... and of course do it at 6K or when the OLM tells you.
opinions
JasonH
Houston, TX
Thanks!
How did you compute 6,000 miles for that trip? Are you making pitstops along the way?
I suggest getting your oil tested the next time you complete the service interval. The oil may be holding up better than you think in your naturally aspirated engine. My oil test came back with very good results after running 7K in my Ecoboost. I can't imagine yours would be worse.
07navi
I would just change it every 5k miles even though you use synthetic but some will disagree. All oil gets contaminated.
David Schaefer
David Schaefer
North Texas
My wife said 2,900 miles each way. That sounded to much, but I didn't want to argue. I googled it just now and it is no where near that far! It should be closer to 1800 each way, plus whatever driving around they do for a week.
David Schaefer
David Schaefer
North Texas
I usually change my own oil, and went to Walmart to get some even though I was tired from helping my daughter move today. They had a sign with oil change prices so I decided to let them do it. $55.02 for a 7 qt. full synthetic oil change on the Expy. Not bad IMO. They did the usual extra stuff that goes with a full service change. I got some new wiper blades too for the trip. All she needs now is a car wash and it will be ready to go.
Thanks for all your comments!
Plati
I always check tire inflation before trip, do oil changes wherever I am.
I usually do 8000 mile trips in August/September ... not this year :flame:
I have a full page list of things to do before trip, like put mail on HOLD
inmanlanier
I run extended intervals on synthetic oil as a result of oil analysis (have in many cars for many years). If you search on my name, you can find the posts and review the results.
Please no denigrating remarks from those that choose to do differently.
lbv150
Northeast
I change oil using Motocraft semi synth every 3000 miles...Oil change is cheap compared to engine components.
Plati
I've done 6K mile oil changes (10W30) on my 2003XLT with 184K miles on it , one step from junkyard due to corrosion and parts failure of other types. Engine still runs great though, no issue there. Have about $1800 banked vs 3K mile oil changes. I fully support people doing whatever makes them happy, but personally I have no reason to believe 3K oil changes prolong engine life. I think that's a waste of time, money, and resources. Imagine if I went on a 9000 mile trip and had to get my oil changed 3 times.
plumcolr
freehold nj
Even if it's only 4k round trip, change it. Would never recommend exceeding 6k on a change regardless of mfgr's recommendations. 3900 + 4000 = almost 8k.
07navi
I've done 6K mile oil changes (10W30) on my 2003XLT with 180K miles on it , one step from junkyard due to corrosion and parts failure of other types. Engine still runs great though, no issue there. Have about $1800 banked vs 3K mile oil changes. I fully support people doing whatever makes them happy, but personally I have no reason to believe 3K oil changes prolong engine life. I think thats a waste of time, money, and resources. Imagine if I went on a 9000 mile trip and had to get my oil changes 3 times.
I agree and I change my synthetic every 5 k miles which is more than enough according to the makers of it.
inmanlanier
Recognize intervals are to protect the manufacturer's interests. They are NOT an interval picked on failure analysis or large sampling of the oils drained from the Ford dealers so they can tweak their interval. Large fleets use analysis to validate that the oil is performing as needed at extended intervals. They don't change at manufacturer's intervals - they change when the oil and/or additive packages are as close to end of life as possible. Numerous auto manufacturers now have long intervals on their cars where the oil change is part of the warranty service and they use synthetic. In other words, now that the company pays, imagine that - the intervals get longer. My F type Jag with 550HP has a 16,000 interval - 550 HP on a 5.0 liter motor is a bit more stressful on oil than our wimpy 5.4L motors; and I can drive on racetracks under warranty! BMW is now 12,000 to 15,000 miles for when they change their synthetic. Why did they change? - because they know synthetic lasts that long. I've been running 15,000 mile intervals on several cars many times - each time I've gone to that interval, it's based on analysis that has demonstrated that the oil and additive packages are fine at those extended intervals in that vehicle with said oil.
