Hello Expedition Guru's...
I have an 03 Eddie Bauer 4X4 5.4L. When I switch the 4x4 dial to 4H the light on the dashboard does not activate. I replaced the IWE solenoid and the transfer case motor and still nothing. I check vacuum at the hubs and that is good and there is no vacuum when I switch the dial to 4H which tells me the hubs are working just fine. I also check all the fuses in the main fuse box - all good.
Could this be a 4x4 Transfer Case Control Module issue? I hear it click when I turn the dial but again no lights on the dashboard and it does not feel like 4x4 is actually engaged. Are there other fuses or relays I can check before changing the TC control module? Anyone else have this no light on the dash and no 4X4 issue?
Thanks!
Thanks!
