Cold start rattle in the turbo
DWs-TTEB
DWs-TTEB
Evans, GA
I took mine in today too. They said the rattle is the cam phasers and the knocking sound I have is the fuel pump (not a problem). They ordered the parts for the cam phasers, so we'll see if that fixes everything.
:confused:
:eek:
If you watch the video I started this thread with. If you remove the driver-side wheel well liner & do a cold start and observe the waste-gate actuator go through it's test cycle (40-53 seconds after engine starting) and hear the rattle its NOT the CAM phasers. My rattle went BYE BYE after a new turbo was installed. Sounds like your Ford service place is just going through the motions man.
5280tunage
colorado
I'm having three same issue, but as I stated in another post, my dealer was apparently told by ford not to do any service for rattling or ticking until they do the phasers. So here I am, going back for who knows now's how long.
mcb345
Nashville, TN
From my dealer this morning regarding the rattling...
“Yes sir that have found an issue with the vct and having to replace the timing chain and components that go with it and then will have to retest.”
Hopefully this is the fix!
MxRacer965
Hudsonville, MI
How prevalent are VCT and wastegates I wonder? Got 10,200 on my ‘19 Max Platinum and seems issues begin to crop up as early as where I’m at in miles...wondering if I’ll be taking it in for VCT and/or turbo in the not so distant future?
Why just the drivers side turbo??
DWs-TTEB
DWs-TTEB
Evans, GA
my passenger side has no rattle. Never did.
5280tunage
colorado
My turbo rattle started around 7k miles (both drivers and passengers).
I never really heard the VCT rattle but ford won't do the turbos till the phaser issue is done. DUMB.
mcb345
Nashville, TN
Yea and if your dealer is anything like mine it’s at least a week for the VCT fix...
5280tunage
colorado
It was a full 4 days and they totally forgot to take care of a couple other items. Then it took me two hours to clean the oil off of the frame and everything else. I also feel like they don't measure the amount of antifreeze that drains out, so they just fill till the overflow reservoir is full, because it freakin spills out and burns the whole way home.
5280tunage
colorado
Update on my turbo rattle.
So today, took it back to the dealer, got to show the heavy line tech exactly what I was hearing, and so far the outcome is not so great. he did find an old TSB for 2017 F150's where there was actually a spring replacement for the wastegate actuator but found nothing for the newer models. He did however find a general service bulletin that states "rattling noises during light throttle are normal" and in a sense absolving Ford from having to fix this. He's submitted a tech line request for review but I'll likely have to fight Ford, on my less than 1yr old pretty expensive vehicle.
If it is normal, than why did it only start when I hit around 7K miles? Why wouldn't an expy sitting right next to it have the same noise? And who wants to pull up next to friends and family with a fairly new, pretty expensive vehicle with a rattle that sounds like a loose exhaust?
Sorry, just venting, I'm not super impressed right now...
DWs-TTEB
DWs-TTEB
Evans, GA
Wow......some old B.S. Guess I lucked out at my local Ford service place.
5280tunage
colorado
Yeah, I'm not happy here, I literally researched reviews of every dealership within an hour of me, these guys had the best, and I believe it, they are trying and they are transparent. So far, the responses from Ford seem to be the issues. I don't blame the service guys.
mcb345
Nashville, TN
I would just bring it to another dealer in a month or so and claim it’s gotten worse and specially ask for the spring replacement or whatever you think the solution would be.
Out of curiosity, is the spring replacement something you can do in a few minutes yourself or does it require removing parts to get in there?
Also, has anyone ever asked a technician or someone from the service department to do easier fixes under the table that maybe a warranty isn’t covering?
Not sure if the spring replacement is easier or not but really asking just a general question.
5280tunage
colorado
Honestly i'm not sure, the TSB the tech showed me was literally only for 2017 F150's. Not sure why it didn't cover more vehicles. My guess is, knowing where those actuators are, it would likely be a huge pain to replace anything on them. The drivers side I could possibly get to through the wheel well, but I think the passenger side may be a bit harder.
Either way, I'll wait and see what the tech line comes back with from Ford, the tech agreed with me on the sound and the fact that it's not on others sitting on the lot. Thanks for the ideas though.
