Wind noise from driver's door?
CubSmurf
Houston
My last car was extremely quiet going down the highway, where the Expedition has LOTS of wind noise from the driver's door.
As far as I can tell it is NOT the large mirror but the gap between the window weather stripping and the window glass itself. There is a lip on the weather stripping that goes away from the glass, presumably to make it easy for window to slide into place. Passenger window had some lip on the weather stripping, so doesn't seem to be a defect.
Do you have loud wind noise from your driver's window?
EDIT: Mine is a 2017 XLT
justinp16ex
It's definitely there, I wouldn't say it's loud or unbearable. Overall my 16 is a quiet ride
C
CubSmurf
Houston
Yeah, I wouldn't call unbearable either. Just more noticeable than my last car. Glad to hear it's not just mine:)
justinp16ex
You're definitely not losing your mind. Especially when oncoming traffic passes by. I'm sure most of them do it. I put about 600 miles a week on a clapped out 06 malibu, so anything is quieter than that thing.
Motorcity muscle
Motorcity
Do not know how many miles on your truck (more door use), but the edge of weatherstrip wears or flattens. Try adding some spacer behind rubber to tighten up gap when door is closed. Piece of cardboard cut in thin strips worked on my barely noticeable noise when radio was off. Front top leading edge is usually the culprit.
07navi
Mt.Shasta California
I agree, the noise was probably less when it was brand new and it has to be air rushing past the rubber.
C
CubSmurf
Houston
67k miles. So, not a ton but not a little either.
It does seem to sound/feel like weather stripping. Are you talking about the door weather stripping or the window? I'll try the cardboard thing when I get a chance. Thanks for the idea!
Motorcity muscle
Motorcity
The door weatherstripping was the problem with mine. My truck is an '07 with 134,700 on mine.
C
CubSmurf
Houston
riphip
Memphis, TN.
I think I read in a past, older, post where this was used. Home Depot only has short 10' lengths from my in store search. At least with 50' lengths I can get the whole seal and use a 3/16' piece of hard tube to connect. My thinking is to take each piece of stripping off & use my cable snake to pull thru with maybe baby powder for lube.
Sorry, thought this posted last night.
C
CubSmurf
Houston
I'm very intrigued by this concept. Please update when you're done and if you figured out any tips/tricks.
