How to shut OFF Traction Control completely?
carymccarr
Earth
I've counted it out while holding the button down. It takes a count of 8 mississippis for my TC to be completely off.
The navigator isn’t a physical button. It’s either “checked” or not. Ugh
DWs-TTEB
Evans, GA
the killing power thing is annoying and dangerous. Last week I pulled onto a street with a moving truck coming down the road, I had about 200+ feet to get up to speed in front of it on a back road (45 MPH). So I gunned it from my stop sign to make a left halfway through the turn the ECM killed the power and I was close to being rear-ended (going like 5MPH for 5 secs). I didn't know this was a thing prior to. Guess my old habits gotta change.
D
Deadman
the killing power thing is annoying and dangerous. Last week I pulled on to a street with a moving truck coming down the road, I had about 200+ feet to get up to speed in front of it on a back road (45 MPH). So I gunned it from my stop sign to make a left halfway through the turn the ECM killed the power and I was close to being rear-ended (going like 5MPH for 5 secs). I didn't know this was a thing prior to. Guess my old habits gotta change.
I've done that in the rain and had a panic moment because like you say it KILLS the power for a long time. Then its almost too late to get moving while traffic is closing in fast!
DWs-TTEB
Evans, GA
using the VCM scanner (RTD | came with 5star stuff) I noticed at idle my expy has 1471 PSI for fuel pressure. when the ECM kills the power in this way as stated above, it must reduce the fuel PSI a lot. Only thing I can image would stop this engine so fast in its exhale of power.
wakeboarder
Fort Lauderdale, FL
I would think that it would just artificially say max throttle is position is 5% or something similar. Since there is no direct linkage to the engine, it could be done with computers.
Thunderbirdsport
Missouri
Drive by wire. It changes the signal to the PCM in regards to throttle position and you can't "override" it without the button being pressed or held in to disable it.
Seems like a lot of variables...on my '11, no matter how long I hold it in, it never flashes and completely shuts off. It The only thing I can do is press the button momentarily. It'll give me a little spin, then it cuts out, and acts like it does without a button press. Weird.
Tocapet
Texas/Colorado
The babysitter kills mine instantly with one push of button. It'll only spin maybe 10 mph and its killing power.
My '09 2WD has that. My driveway is uphill into my garage. With the TC on, it alternates rapidly between the L and R rear wheels trying to find traction on the ice and frozen snow. If I turn it off, I can make it into the garage easier by spinning both wheels to gain a little traction. My house faces North, so the driveway is the last to melt. In Colorado
1970Maverick
orlando, fl
It seems like there are too many varieties of TC and many(not all) of the owners' comments are made about their SUV/truck without stating which year, model and trim level they have. Without stating the year model the info may not be applicable to what you are driving.
I drive a 2017 XLT no options
MHay
The OP said he has a 2018. This is the 4th Gen forum so references to the owners manual seem to be relevant to 4th gen trucks.
carymccarr
Earth
Can’t imagine there are that many differences in 4th gen when it comes to turning off TC
wakeboarder
Fort Lauderdale, FL
That is what the signature area is for so you don’t have to write it every time you post.
D
Deadman
I thought that was the area where you push your chest out and write every vehicle you have ever owned and sold 15 years ago. lol. Those signatures just make my eyes rollllllllllllllllllllllllll
Thunderbirdsport
Missouri
And in my sig are the vehicles I'll admit to owning (as opposed to no longer owning) ;)
And since mine's "only" an '11, I'll bow outta here.
'sniff. Gonna miss you guys
:D
D
Deadman
:D
If you still own them, thats one thing. It annoys me when the guys post everything they've sold in the last 20 years....
Fozzy
Riverton
I only use Tapatalk and never see anyone’s signatures. Is there a setting?
wakeboarder
Fort Lauderdale, FL
I just look at it on my iphone browser (not Tapatalk). I don’t see signature until I turn it in landscape mode.
