2014 expy front Strut Replacement help.
Ron1978
Ms
Is this a straight forward replacement, and extra steps I need to know before I start. I ordered the KYB complete from struts $328
Shipped from Rockauto. They will be here soon. Any advice will help. It does not have air ride or lvl system
Ron1978
Ron1978
Ms
It wasn’t hard at all to swap out. Loosen sway bar on the side your working on, take off upper control arm joint, take off steering arm joint and remove the Abs and brake line holders. Then take off top 3 nuts and 2 lower nuts and push down on lower arm and remove strut. Go backwards and reinstall it all. Easy work. About 3 hrs with hand tools. The front will ride higher till springs set in.
Hamfisted
Ft Lauderdale
With it sitting on the ground, how much compressibility do you have in the front springs? When I used KYBs on my Gen2, I only had about an inch of compressibility and they were bottoming out all the time. I think the springs were too soft. I went back to the stock Motorcraft units and the ride is back to new, with the correct ride height. How many spring coils do you count from the strut base to the top mount?
Ron1978
Ron1978
Ms
We took a 2 hr drive on interstate and no issues at all, feels so much more stable.
Now I need to replace rear and it’ll feel new.96k miles on it now
2011EL
Houston
That's good to hear. I was looking at the same KYB strut assemblies. But I'm very confused now as the Ford Parts site claims we have shocks in the front and struts in the back. But, KYB offers complete struts assemblies for front and rear. Are you still happy with the front struts? Did you replace the rears as well after all?
Can anyone shed any light on the difference between shocks and struts? Is there an obvious reason why you would want one over the other? And, is there an issue running struts in a truck when OE calls for shocks?
Thanks for the assistance!
Ron1978
Ron1978
Ms
Struts will be a shock with a coil around it, plain shocks are just shocks
on the front on our expy is struts. Havnt changed rear yet
dcsang
Don't forget the alignment even if the steering feels okay. Hopefully you have qualified shops nearby.
