Front Differential Making Noise
fvernet
Rockville, MD
Hi everyone,
I brought my 2011 Expy in to the local dealer as I can hear some rubbing coming from the driver's side front wheel area. This is their finding:
RECOMMEND REMOVE THE FRONT DIFFERENTIAL AND OVERHAUL IT, REPLACE CARRIER AND PINION BEARINGS AND CUPS. (THE FRONT DIFFERENTIAL BEARINGS ARE MAKING NOISE.) $2,540.80
I have no idea if this is a reasonable price and welcome your thoughts.
Thanks
07navi
Mt.Shasta California
Sounds horrible, tear it apart yourself. They usually last forever unless they take on water or leak. Leaving in 4 auto all the time doesn't help either.
F
fvernet
Rockville, MD
Yep - horrible it is. Not sure I have the energy, skillset and tools to tear it apart myself. Your note about "Leaving in 4 auto all the time..." has me a bit worried as I very seldom select "4 auto" and, if I do, it is for a very short time in conditions that warrant it. Last time I used it was this winter in heavy snow as I went up my driveway - for all of 3-4 minutes.
Plati
Does the noise go away when in 2H?
Some people say everything in front of Transfer Case is disconnected in 2H.
Not totally convinced of that.
If it was mine, I`d ask for a guarantee that advised service fixes the problem.
Could do all that and still have issue.
07navi
You can leave it in 4 auto , just not all the time for no reason. At least take the cover off and move the carrier with a bar to check for bad bearings. Or have a mechanical type friend look at the inside too.
Plati
Look I don't know much but I also would verify front brake not dragging. One way to do that is measure the rotor temperatures (left vs right) with a handheld non contact infrared thermometer. I recently associated a rubbing noise with a bad caliper using that method. One rotor was hotter than the other. BTW the noise was at lower speeds only and I could associate that with braking and it also didn't roll quite right. Good luck.
I still don't know for sure but I don't think front diff turns in 2H unless the vacuum IWE is not working right on a wheel and the wheel ends up driving the front diff.
Put it in 4A to let the hubs lock up and drive around to make sure it’s not a hub actuator diaphragm partially locked and unlocked from a vacuum leak.
mnachreiner86
Missouri
07 Navi do you see yet ANOTHER front diff concern? To the OP I had the same thing, labor is right at about $900. I saw mine pulled apart and those races and bearings weren’t pretty and it’s spent it’s life as a highway queen. I had the metallic rubbing sound you are describing and I started with brakes and went deeper knocking out heat shields, pads, rotors, hubs and IWE on both sides. As the others test everything first and if it’s not there its in the front diff. I do most everything myself but with a new baby at the time I didn’t have time to get into a diff rebuild even though we’ve done them on Mustangs. Good luck!
Dcleghorn01
