A few problems maybe someone can help with
Bertbon
NORTH MS
2000 Ford Expedition Eddie Bauer 5.4L w/towing
I hope I'm posting this in the right spot. Along with having problems with my running boards not lighting.
I can't get my front 2 windows to roll down. I can hear it click when I try the driver side but nothing moves on the window.
Also my horn and steering wheel cruise controls don't work. Is this something normal? Please help!
Robert Wagner
Central Texas
There was a recall on the cruise control system. My cruise control stopped working and I took it to Ford to fix. They replaced a module, as part of the recall, and it began working again. May you be so lucky here. :happy107:
Bertbon
Bertbon
NORTH MS
Thanks Robert, that's definitely worth a try!! I might be that lucky.
Yeah Craig I've heard about the leaky windshields that the First Gen Expy's are famous for but I didn't know what kind of damage it would cause. I'll go to Ford and have them look at that module. Thank y'all
craig sargood
I’d agree with everyone except the fact he’s got multiple problems, odds are all those are not all broken at the same time. The gem module controls many many things. Mine made the radio turn on and off and and made running board lights turn off and on when driving. I believe it’s about $150 to buy and swap yourself. It’s under the dash near pedals. I’d imagine Ford is gonna rape you to do this.
hobbyguy
I have the exact same truck(2000) and I had some issues with the harness up the steering column getting piched from the "wheel tilt" causing some of those problems. My two sense.
tinkering
Alberta Canada
I think Craig is speaking wise words about the GEM. Don't go to Ford, they will rape you:)
Go to the wreckers and grab 2 or 3 of them.
Bertbon
Bertbon
NORTH MS
Can I jump the window reg through the wires that go to the switches or do I have to take the whole door panel off?
Can I replace it with any Expy GEM module or does it have to be replaced with another EB, Navigator, or Blackwood GEM module?
Yupster Dog
Moderator
Year, trim, engine
Take the panel off see what you are working with. (super easy and the panel is off in less than 5 min. (lots of youtube vids on it)
Welcome to the forum.
Bertbon
Bertbon
NORTH MS
Ok
2000 Expy Eddie Bauer 4×4
I thought I had it to where it said the year & trim when I post but I didn't do something right
tinkering
Alberta Canada
I think you could jump it from the switch. Go to the down stream side of the switch with the positive. I don't know if the Gems are interchangable. Try amazon parts applications if no one has that info here. I will see what I can find.
Bertbon
Bertbon
NORTH MS
2000 Expy EB 4×4
Will any expy GEM module work or does it have to match mine?
tinkering
Alberta Canada
2000 Expy EB 4×4
Did you ever have a problem with the drivers window rolling down randomly on its own initiative before it quit working altogether?
If so there is a way to bypass the GEM to fix that shown on a UTube vid. Easy
tinkering
Alberta Canada
If your GEM has been receiving moisture you could try CRC Electrical Cleaner on the pins and plug connections. See if there is green corrosion present.
Some problems can be caused by moisture and the fusebox too. The GEM is directly behind the fusebox.
tinkering
Alberta Canada
It looks like the Ford GEM Module will fit a number of different models but it does have to be programmed or 'flashed' in the vehicle. UTube has videos on it.
I might have some GEM problems too. I myself will try the wreckers route, and to try to make the job easier I will try to find the exact same year, model, trim, engine etc. if possible.
Does somebody in our forum here have some details to help us with this?
