For people with grill lights
Nokturnal
Ft Bragg, NC
Just looking for pictures of 1st gen expys with grill lights (kc's/hellas behind grill). Anybody who's got them post them up.
Racenut
Deming, New Mexico
Hella 500FF. I mounted them horizontaly to the fiberglass reinforcment so that I would not block alot of air flow to the center of the radiator. I live in southern New Mexico and do alot of towing and I have never seen over 200 on the aftermarket temp gauge. It also makes it easier to re-aim the lights to catch the shoulder in deer country ( saved my front end twice on my last trip to San Antonio thru the hill country at 2am )
01 Expo
Hella 500s with 100 watt bulbs on rack and in grill
panda24619
San Diego
look at my photo album. i have a few in there. theyre KC Daylighters 130 watt chrome.
2001Expy
MI
How easy is it to install the wiring for the hella 500 kit?
Racenut
Deming, New Mexico
Simple you only have to run 1 wire inside the cab the rest are under the hood. The wire that you run inside will conect to the switch ( where ever you put it ) and then you just need to tap power and ground for the switch.
The relay assembly under the hood gets hooked to the battery and ground, then you hook up the lights power wire and your done.
2001Expy
MI
Thank you for your answer. What would be a good location to put the switch in? If I had a lot of time and skill, I would mount it in the overhead console in the garage door opener area.
Racenut
Deming, New Mexico
I put mine in the center console just in front of the cup holders dead center. It makes it nice to have it in easy reach, but it can also get you in trouble because it is that much easier to hit when some one is on coming with their brights on.
2001Expy
MI
Yea, i know what you mean. I hate people who leave their brights on in an intersection and your right across from them.
Racenut
Deming, New Mexico
how are you guys mounting the lights yo or behind the grill
Some guys are mounting them to the fiberglass cross bar that runs left to right behind the grille, I myself mounted them to the vertical fiberglass supports on the sides.
Just drill thru and use the supplied hardware for the lights. If you get really heavy lights I would recomend using thin steel plates on each side to distribute the load.
panda24619
San Diego
i have mine on that cross bar but when i went to tighten the bolt the nut when threw. so i had some big washers laying around so put those in the crossbar so there was some strength and no problems now. i want to move it out of the grill but i want 4 lights to put on top first. like nvys.
HFFH
sacramento
awsome thanks for the info. wut size lights are you runnin,4 or 6 inch.
Racenut
Deming, New Mexico
I am running the 6" Hella 500FF lights. They are only a couple of inches thick and don't weigh very much at all. They are also a spot light style beam so they go pretty far.
panda24619
San Diego
6" are mine. i really want to run 6 lights up top but i dont think the rack is wide enough. so i have to make my own. but my lights are thick but ive seen a f150 by my uncles that had 4 kc daylights behind his grill so its possible to do that.
