Hi, the temp on the display shows around 65-75 degrees - thats Celsius.
Can someone help me identify the responsible sensor, to check if its faulty or just in the wrong place.
Expedition 2017 limited.
Thanks
Yes i did change to Fahrenheit still high, will check the sensor itself. Maybe it isnt positioned correctly / blocked / damaged.
Any reference picture, is it on the right or left side? and top or bottom?
Thanks
Thanks
why do I see two different temps? there is one next to the "house" icon that shows 17.5 and the other next to the time that shows 73.
Its always lower at start and going high in few minute.If the truck was parked in the sun on a hot day, a reading like that is normal. I have had temps up to ~160F after the truck sits in the sun for the afternoon.
Its usually between 35-40 celcius now a days. At start its within this range and then goes upCurious, what was the actual ambient temperature when this displayed 73? Is it possible that the software was not making the conversion from f to c?
Is this where the the three holes are...?On my 2015 Expedition, the ambient air sensor is mounted on the right (passenger) side, in front of the a/c condenser - attached to the upper portion of the radiator core support.
It is easily visible through the radiator grille, and could be easily changed in a minute or two by reaching through the grille opening. If you have large hands, you could easily remove the upper plastic radiator close out panel and reach down to access the sensor.
Sent from my SM-G986B using Tapatalk
Yes correct, it has a history of frontal repair and i suspect was not done by the dealership, as another thing i found missing was the hood ajar switch.Could it have come loose and laying up against the radiator now ? If you don't run the motor in the morning and just turn the accessory power on does the display temperature stay about right ?
So it might be misplaced...
OK but why do you have one temp in Fahrenheit and the other two in Celsius ?Climate control for the driver and passenger zones The display is showing the set cabin temperatures. If you notice in the top right corner of the display, there is another 17.5 in the glare.
All in in celcius, right and left are a/c front and back. Middle one is the external / ambient and this reading is offOK but why do you have one temp in Fahrenheit and the other two in Celsius ?
