White smoke on startup and code P0300?
Texas Dave
Fairfield, TX
My 2007 Expy with the 5.4L and 300,000 miles has recently started doing strange things. On the first startup of the day it emits thick white smoke for about 5 seconds. After that, no smoke the rest of the day. It has a rough idle and obvious misfires at low speeds. However, at highway speeds it runs very strong. Accelerates to pass like a beast. Scan shows a P0300 code. My thinking is a vacuum leak due to the fact that it runs perfect at high speeds. Just for grins I changed the MAF sensor which did not help. Any ideas what to look for?
99WhiteC5Coupe
Has your engine coolant level dropped?
Some have posted on this forum about a heater-hose (or connector fitting) leak on the right rear side, causing coolant to enter the spark plug tube(s) and cause a misfire.
The thick white smoke may indicate a head gasket leak.
Texas Dave
Texas Dave
Fairfield, TX
The coolant level is normal. The smoke disappears after about 5 seconds. The rough idle and misfires at slow speeds continue all day.
GlennSullivan
NY & FL
Start the engine, let it smoke for a few (2) minutes, shut it off, then carefully run a gloved finger on the inside of the tailpipe and examine what comes out for smell and feel - It should not be very hot after only a few minutes. It should tell you if it is oil or coolant.
Texas Dave
Texas Dave
Fairfield, TX
It only smokes for 5 seconds. I let it run for a couple of minutes and did what you said. It was wet but had no smell. Perhaps just water vapor?
Pilgrim
SK. Canada
White smoke generally indicates water and/or coolant in the cylinders. Possibly head gasket or?? P0300 is random misfires which could be connected to the smoke or other things like plugs, coils, ....?
Texas Dave
Texas Dave
Fairfield, TX
PROBLEM SOLVED: It was a camshaft position sensor on the passenger side. $25 and about 30 minutes work and no rough idle, no codes, and no check engine light. Runs great.
