4th gen power running board motor
Guzz
Stephens City
I started having problems with my passenger side power running board. Sometimes it starts to retract but returns to the extended position. I've searched for motors but can't find any that show they fit a 2018 or newer, just 2017 and earlier. Are the 3rd gen motors a direct replacement for the 4th gen?
KJ-Idaho
Boise ID
I started having probs just like yours two months ago. One dealer cleaned and lubed the step but that didn’t help. The second dealer seemed more knowledgeable and responsive: replaced a Motor on it. No fix. They have received an actuator that is separate from the motor and believe it is the fix. Still under warranty. Appt Thursday. Will post the results.
lv2drive
PA, USA
just started happening today. retracts but then extends . intermittent (of course.)
Guzz
Guzz
Stephens City
Took a pic of the part label on the passenger side running board motor. I think that I will order a motor without bracket off amazon and compare side by side to see. I can return the amazon motor very easily if it isn't compatible, just drop it off at the local Kohl's store, they accept returns. I will go with any that match up electrically plug-wise. I've noticed that some are round and others are square with rounded corners. Found a site with images for OEM parts, will have to actually get the correct part # as they have more than two options, even though I specified expedition max. (If I'm forced to buy from ford, $300+ for one side)
Guzz
Guzz
Stephens City
Took off the passenger side motor/hinge front and back. Ordered this pair. The motor is the only thing that I plan on changing. Local dealer quoted me a price for the JL10016A506J $475.75 plus tax (motor and hinge assembly). I will update again when the amazon motors come in.
Guzz
Guzz
Stephens City
Just to close out this thread as an FYI. The motors that I bought from amazon are ALMOST an exact match. Three exceptions: 1. The flat spot on the shaft that the wedge seats in was longer than the 4th gen but had zero impact on use. 2. The polarity is reversed but easily fixed. (the running board wants to go in when the door is open and out when closed) To reverse the polarity, I simply cut and swapped the wires on the side of the harness plug with two pins. When plugged into the vehicle, the motor responded correctly producing the 1/4 turn in the correct direction (clockwise/counter clockwise) to operate the running board. 3. The holes that the plastic cover is screwed into are not threaded and may be drilled slightly bigger than the original part. I just tapped it and used a bolt out of my coffee-can-of-bolts.
After all that, I got the same issue, starts to retract but comes back out. Finally broke out the oil pump can and liberally applied regular motor oil all over the hinges. Yes this fixed it. Now every time that I change the oil, I drench the hinges on the running boards. I left the new motor on.
Vipersinu2
No need to cut wires,, If your motor is running backwards, take out the 3 phillips screws on the back cap and spin the cap 180°. That will fix your issue running in reverse.
Results?
StephenPT
Portland, OR
Ford Tech Makuloco on YouTube has a video about maintaining the running boards and getting them unstuck if they are stuck. He mentions in the video that more often than not the problem is just not enough lubrication on the hinges so the motor reaches its torque limit and then reverses. https://www.youtube.com/watch?v=oaAvrIoViK0
Mustangsally
Saratoga
Same problem on my F 150 Platinum and my wife's Expedition Limited. I watched the video above about lubing the hinges . Worked great. All boards are fast now and don't stop any more. I used PB blaster as a penetrant.
The Yeti
Glenview
Running into this issue now on my 2018 Expedition. Hinges were supposedly lubed by dealer at each 5K service. Even with my feedback that boards occasionally stick and I thought there could be a bigger issue, the dealers said lubing was the only approach needed. Now at 45K mileage (and outside of warranty), dealer is saying motors need to be replaced at $1500 each. Not happy, but working with the dealer and Ford Corp to try for resolution. Just a point of caution for others still within warranty... Be sure to DOCUMENT every time you have hinges lubed and when you claim boards are not working correctly.
Gumby
Beaumont, Alberta
I turned my running boards off about a year ago. After many dealer lubing and cleaning, the motors finally "gave out" apparently and at about $1500 each to replace that was a no go. Plus I hate the look of powered running boards that are constantly in the out position. To me they are not as good looking as a fixed running board or step bar.
The Yeti
Glenview
Update: Dealer worked with Ford Corp on my behalf and is offering to significantly offset the cost. I think the resolution is fair, so I'll be moving forward with the repair.
It sounds like an unfortunate design flaw. I wouldn't mind a fixed running board, but I do NOT want to leave these boards in the down position. Too many snag points when driving through hunting fields, etc. Better off removing them completely.
WrekEE
does anyone know if these are amp research? If so amp research uses electricstep.com as their parts dept. Maybe getting the parts through there are cheaper.
5280tunage
colorado
i believe they are Amp, comparing them to some of the aftermarket Amp products, on raptors and others, they seem pretty identical.
Mossman
iowa
Anyone know or have the running board plug pinout for these? I have one side not working at all. Want to check power at pins.
Can’t hear anything to the motor so thinking maybe a bad wire connection to it.
