2004 X
kmz28
United Kingdom
Just wanted to say whatz up to everyone and post a pic of my X. I've been a member for some time now, but I'm in the military stationed overseas so the past year or so I've really been busy. But I found my username and password and would like to get actively involved in the website now. I've got tons of questions about Expeditions, so after I go through some of the posts, if I can't find the answers I'm looking for, hopefully I'll find some help from some of you!! Thanks everyone, and let me know what you think about my pic...
bnvus
Stafford, VA
Sweet...Tell me did you put in the HID projector lights? It looks like it.
K
kmz28
United Kingdom
bnvus
Actually those lights aren't HID's...They're just some dual Halo Ring or "Angel Eye" lights I got off Ebay for like $200 for the pair. Can't remember the brand name though...They do look pretty kool cruisin around at dusk with the parking lamps on and they really helped changed the look, but, they are a bit fragile on install/remove, particularly the Halo Rings...The connections for the rings just seemed to be delicate cuzz I had to get my lights converted for England and the guy broke one of the diodes on the front left ring...Not sure if it's repairable either, I'm working that now...If you're interested, I'll keep you posted...
Also everyone, thanks for the responses...
K
kmz28
United Kingdom
Window Tint
To be honest with you on the tint, it's really not...All the windows have a medium tint, but since the front two are the only ones without factory tint, all the rest look really dark...And they are...pretty dark, but not that dark...I do have a hard time seeing sometimes, but England has a somewhat strict law on window tint on the front two windows...They set up check points and pull cars over to use this "light measuring" thing to see how much light is let through your front windows...If it fails, you don't just get a ticket, you can't move your vehicle until the tint is taken off!! Yep, you're right...you either tear it off on the spot or hope you're not far from home for a nice walk...
janz
So Cal
Sup kmz28, I just got a pair of black dual halo headlights off ebay. I have a black X so i thought I'd go with the black ones. Did you replace the bulbs the headlights came with or did u just stick with how you got it? I wan't to replace mines with super white bulbs but i'm not quite sure if i should mess with em. Also did you have to modify anything before you installed them? I haven't gotten a chance to look how the stock headlights plugged in. Is it just one plug? And for my last question, did you just attach the wires for the angel eyes directly to the parking/signal lights? Could you e-mail me as to how you did it? Cuz I don't want to mess anything up. Thanks.
K
kmz28
United Kingdom
Halo Lights
Janz
Hey whatz up...I'm gonna try to answer your questions before I am late for work so I apologize if they are short. First off, I didn't modify anything to put them in. They are plug and play. I was actually so anxious to get them in to see what they looked like that I just installed them to get a quick look. They plug in like the factory ones do (I think 2 plugs), and yes, there is a few solo wires for the halo rings to hook up. I didn't hook those up initially. When I had all my stereo stuff thrown in, the stereo guy hooked them up for me so I'm not sure how he wired them. I assume similar to what you said. I haven't put any extra lights in either, the ones that come with it seem to be ok, though the factory lights are a lot better. I just have to remind myself that these lights are more based on looks than the lighting feature...Not to say that they aren't good lights, they light well enough, I just feel the factory ones are brighter...Anywayz, I gotta jet out, so if you have anymore questions just drop me a line...
janz
So Cal
Thanks for the response, I replaced the all the bulbs 2day with hyper whites for both the low beams & high beams and changed the amber side/parking lights with some yellow ones. The high beams were kinda a struggle but do-able. You mentioned that you have altezza style tail lights? You have any pixs & could you refer as to where I can get some? I'll post some pixs after I finish all the installs. Thnaks again.
K
kmz28
United Kingdom
Janz
Your install sounds like it went pretty smooth. I would definitely like to change my bulbs I just haven't had the time to look into it. Here are the tail lights that I have and the place where I got them: http://www.matrixracing.com/BI5316Details.htm They were $198, 6 months ago and haven't changed much. I think this is probably the cheapest you can find these particular lights, even on Ebay. They're pretty decent and there's about 5 variations. Here are the headlights that I have, but I got them off Ebay for $220: http://www.matrixracing.com/BI4449Details.htm There's a few variations of these also. I'd definitely like to see your finished product once your all done!
janz
So Cal
Thanks for the linx' The tail lights look like there's no outer clear lens. Is this how they come or do they have a clear outer protective lens on them. Just want to know b4 I purchase them. I like either the black with red flames or the carbon fiber ones.
janz
So Cal
Finaly got the Xpi back from the shop...Here's a pix of the projectors with dual angel eyes I took 2nite. Along with the new headlights we installed super white low & high beams & yellow parking/signal bulbs...Will be intalling the yellow fog light bulbs 2morrow morning & will take more pixs to post...
K
kmz28
United Kingdom
Sorry bout the delay on the clear part on the tail lamps. I thought I replied already but coming back I realized that I didn't. Yes, they are chrome on the insided and have a clear cover on the outside. They're pretty decent too, though they fog up alot. But I am in England and the weather here is unforgiving. Now, your angel eye's are looking nice! Doesn't it just really make that front end stand out?! You think you can direct me to where you got the super lows and highs? I'd like to look into those. Was it a difficult upgrade? thanks
janz
So Cal
Yeah it does...I took some more pixs...
You can go to this link to view the pixs i took..
Janzen's Xpi
DSC03847
ObliQ
Minneapolis, MN
Nice truck, man. I was wondering where everyone gets their small lower grilles from. I just ordered a chrome honeycomb pattern front grille, but I can't find the smaller lower grille to match like you guys have to match your billet grilles. Please advise.
