Just for fun I installed the drop brackets that let you keep the sensors. You will loose 3" of ground clearance at the front diff. Not worth in in my opinion.
Rear drop bracket hangs way down. Factory skid plate is flush with crossmember.
The entire bumper hangs way to low to be useful. It would only be for looks installed like this. The soft aluminum spacers would be weak in a collision. But you do get to keep the sensors.
Without the trim installed at the lower setting for the sensors.
Side shot. I have already cut over an inch to clear my tires and screwed the carpet back. Looks like the bumper will be about where I have trimmed the fender.
