Gravel feel when accelerating
Shantheman73
Kansas City
Hey all…weird symptom I’m experiencing.
When I’m accelerating hard, I get this gravel rough feeling coming thru the gas pedal…almost like it’s coming from front diff or maybe the axle trying to engage 4x4 or something. Under normal acceleration it feels normal and smooth as always.
It shifts fine in either circumstance, but maybe its torque converter related? Front diff?
It’s a 2007 Limited 4x4
Shantheman73
Shantheman73
Kansas City
Bump. Curious if anyone has any thoughts. I’m wondering if it could be engine related too…since I’m feeling it thru gas pedal?
Trainmaster
Old School Member
Rockaway Beach, NY
When was the last time the infamous spark plugs were all changed? My initial thought is that it is a miss. Nobody likes changing those plugs, so if you didn't change them yourself it's quite possible that they have not all been changed any time recently.
Shantheman73
Shantheman73
Kansas City
Good thought. I had Ford change them about year and half ago…20k miles ago.
It also had a bad coil pack at the time…and I recall what that felt like. This is definitely different. ‍
Shantheman73
Shantheman73
Kansas City
The more I think about it…it’s gotta be engine related. Would coil packs cause this type of behavior when they go bad? The last one that went bad…it just caused hesitating at certain RPM’s. What other symptoms might point to bad coil packs?
sjwelds
Kansas
I think it could be related to the 4wd system. It is vacuum operated, and there isn't much vacuum under hard acceleration.
I had similar issues with my 2012 and a new vacuum check valve fixed it. I will say that I never felt it in the pedal tho, it was more of a noise that I'd hear that I knew wasn't quite right... Ymmv
Nickp33
Georgia
This happened on mine. Mine was a wheel barring on front left wheel. Would have sworn it was something different at the time. Good luck.
Goofy173
Ky
Yes. Wheel bearing. They'll be felt in the pedal and usually the steering. May change on acceleration, braking, and /or turning.
Dustin Gebhardt
Tulsa, OK
This is probably the IWE's engaging partially under low-vacuum conditions. I had the exact same issue in my '07 and I discovered that my vacuum line running across the front crossmember had a hole worn in it. I fixed the line and everything got better.
mjp2
Howell, NJ
How old is the transmission fluid? If it's been more than 100k miles it's worth swapping for the sake of maintenance even if it doesn't fix this particular issue.
Shantheman73
Shantheman73
Kansas City
Where was the hole worn thru? Maybe I can trace same area to check. Did you feel that during acceleration?
