Jreidg3
I finally changed out the ugly halogens for LEDs on my 2018 limited today. So much cleaner looking and much more crisp going down the road at night. I used switchback bulbs for the fog lights. I had already used these on my Honda Pilot. They work great and are really distinct in rain/snow/fog. Fair warning that installing the switch back bulb on the drivers side fog light required me to pull back slightly on the metal bracket behind the bulb. Nothing major at all but you need just a smidge more room to sneak the bulb in. Install was super easy once I located my 5.5mm socket to remove the three wheel well screws to access all three bulbs. The high beam and low beam led ballasts were able to be tucked inside the headlight housing and reinstall the rubber dust cap. I looped the fog light led ballast around the fog light housing to shorten it up a little and keep it from banging around.Products purchased on Amazon:
SEALIGHT 9005/HB3 H11/H9 14000LM LED Bulbs Combo Package CSP Chips 6000K Cool White https://www.amazon.com/dp/B07K438ZQ...abc_XR42QJR2ZXCECS6XG91C?_encoding=UTF8&psc=1
ALLA Lighting H8 H9 H11 LED Switchback Fog Lights, High, Low Beam Conversion Kits, DRL, Dual Color 6000K White/3200K Yellow 12V H16 H8LL H11LL H965W, Extremely Super Bright 8000 Lumens https://www.amazon.com/dp/B07KM3WTW...abc_94NVVJZGW8MJBV2GKGJ9?_encoding=UTF8&psc=1
