2020 Expy Bambi mode
Shep
Pa
I can’t find the place to turn Bambi mode on like I did with my 2017 f350.
Moderator
Are you running the newest version of FORSCAN? FORSCAN doesn’t call it Bambi mode. It is Fogs on with High beams, and you can also select to keep lows on with highs. It is in the BCM drop down options. No coding needed. Also a search would have found this…
Rednecked
Arizona
I don’t even have a drop down menu for BCM. I am running the newest version.
2021 Expedition Max
jfreeman6
Atlanta
The Forscan Codes/Spreadsheet that covers 2015-17 and then 18+ Expedition does not support 2020s or 2021s.
I just had major issues trying to use the sheet.
I then switched to the sheet for my 2020 F350 and it worked in my friends 2020 Expedition and my 2021 Expedition.
Something has changed and the current spreadsheet is really out-dated.
Rednecked
Arizona
I contacted FORscan support last week. They are working on an update release for the 2021 Expeditions.
I couldn’t get anything to stick on my end. I don’t even have a quick drop down menu for BCM module.
I guess we wait…
Moderator
Dude, you are a broken record. Did you even read the thread, or the others before commenting?
