No Limited Slip Differential : What's the impact on Towing?
wannabeMtb
San Francisco
I ordered a 2022 expedition and forgot to add the Limited Slip Differential option. What is the impact on towing? I mean will that mean that I can't tow in sandy/muddy roads or something like that ?
Anerbe
Mi
I expect you would see the true impact when moving from standstill, towing on slippery surface, like one side in sand/snow or perhaps a boat ramp with one side having less traction. Brake based limited slip can only send up to 50% of the power to one side, while it brakes the opposite end to create equal force between the low traction and high traction side.
Highway, or conditions with equal traction left/right, you shouldn't see a difference.
JasonH
Houston, TX
If you're towing on improved roads, there will be no impact. I haven't towed in heavy snow, sand, etc, but it's never been an issue for me.
W
wannabeMtb
San Francisco
Thank you.
I assume you meant that you don't have Limited Slip Differential ; and yet had no problem with towing. Correct ?
duneslider
Utah
I haven't looked into the 2022's but on the previous years the LSD was standard when you ordered the HD tow. HD Tow added the LSD and full rear selectable locker. Is that no longer the case?
Going_Going_Gone
Phoenix
I know that with the '21 models, elsd was removed from the HD tow pkg., and only available as a package option (with controltrack) for more $$
JasonH
Houston, TX
Thank you.
Yes, that is correct. I have a 4x2 with 3.31 and no LSD. It's never been an issue, even on gravel or grass. I have gotten stuck in deep mud twice, but wasn't towing. The closest I ever came to wanted it on an incline with wet grass, and even then it was non-issue. There was some minor slippage, but I was still able to maneuver the trailer into its parking spot.
wakeboarder
Fort Lauderdale, FL
Watch this video for Ford’s marketing input.
Ford Elsd
In order to test the effectiveness, somebody would need to pull the fuse for the eLSD, then find an unstable condition. After finding the unstable condition, they would need to plug the fuse back in and retest.
I think it depends more on the situations that you think you will use the expedition. If you think you will encounter situations where a front and back tire will have reduced traction at the same time, then the eLSD may be desired.
If it makes you feel better—tires make more difference than lsd vs open diff. My Expedition with no Lsd walks right up the steep icey incline side entrance to one of my properties in 4-low. My dads F-250 cannot make it in 4-low WITH the factory locker engaged. The Michelins beat out BFG hard there. Both sets about a year old. I’m sure good tires with the locker are even better—but point is with good rubber you’ll be set up better than a factory lsd setup.
duneslider
Utah
I have never been a huge fan of Limited Slip Diffs. A selectable locker is nice to have but if my elsd is doing anything I can't tell especially with the nanny controls activated. When I push the button to get a little more wheel spin it doesn't feel any different than my other vehicles with open diffs.
I wouldn't worry about not having it. If you do venture off the paved roads often the selectable rear locker is nice to have but I can't say its totally needed on a vehicle like an expedition. I used it once in some deep soft sand. I don't know if I would have gotten stuck without it but...
Boostedbus
I like my LSD but it can put you in the ditch a lot faster with a road cambered towards the runoff ditch. This picture was last year on my cabin driveway with the joke Hankook factory tires. I also tried it in 4-low and didn’t build momentum. I’d bet my new Michelin Defenders and 4-Hi would make it a lot farther up but I would still have to know when to lift to keep it from fishtailing into the ditch. Oh yeah the Bighorn tires on my buggy had no problems in 2-wheel drive even….lol.70E295AC-F548-4542-8D7B-E8439234211B.jpeg
W
wannabeMtb
San Francisco
the bigger issue is the sluggish performance without the 3.73s. Having driven both, it’s night and day.
Sorry, could you please explain what that sentence means for a simple idiot like me :)
I am not sure whether I have the 3.73 or not. Is that included with the HD tow pkg in 2022 ?
W
wannabeMtb
San Francisco
I like my LSD but it can put you in the ditch a lot faster with a road cambered towards the runoff ditch. This picture was last year on my cabin driveway with the joke Hankook factory tires. I also tried it in 4-low and didn’t build momentum. I’d bet my new Michelin Defenders and 4-Hi would make it a lot farther up but I would still have to know when to lift to keep it from fishtailing into the ditch. Oh yeah the Bighorn tires on my buggy had no problems in 2-wheel drive even….lol.View attachment 71640
Wow. Thats some serious towing !
My use case will be super tame by comparison. Just driving in non-snow conditions to regular commercial RV campgrounds or maybe boat launch.
Boostedbus
Good tires and weight distribution is also key to success. Your dad’s F250 probably didn’t have any weight on the rear axle either I’m guessing? I could probably push a snowplow with my 2-wd E-350 utility van because of its weight on the rear axle that I carry. It’s got a 4:10 LSD.
Boostedbus
I haven’t driven or towed anything with any other Expedition but mine. I have 3:73 LSD and I must say it’s an impressive beast towing!
Moderator
Always better to have the LSD and not need it, than not have it and need it. Just change your order.
Also for clarity. The Expedition has an ELSD(Electronic Limited Slip Differential), and the "Locker" mode is a simulated locker. It locks the clutches as best it can. It is not the same as the 150/250 ELD(Electronic Locking Differential). That is a pin locked diff. No clutches.
Our ELSD does an excellent job under slippery conditions, at modulating torque to both wheels.
balthisar
SE Michigan
I didn't order the ELSD, but given that I already have a build date and price level 215, I don't want to change my order. I started this adventure way back in July (for a '21), and don't want to wait any longer. The good news from this thread is that like the OP, I don't think I'm going to worry about it. It seems like as long as I'm not trying to pull a trailer through the Mckinney-Rubicon trail, I'll be okay.
Moderator
You are in Michigan, so guessing a decent amount of Snow a year. Why wouldn't you just edit the order, this should not effect your build date, but I don't know that for sure. Worth a question to your dealer or Ford Support directly.
For me if I am spending as much as these cost, I am going to dang sure make sure it has the options I want, and ELSD makes a big difference in how this things handles slippery conditions.
That is me. Enjoy.
