Intermittent rough idle
SDR93
canada
Hello everyone,
New member here. I moved to Canada from the UK late last year, when I arrived here I instantly had an urge to buy a big truck, so I decided to buy a 2009 Eddie Bauer on 164k miles.
I love this car and have enjoyed some great journeys exploring this new country. However, shortly after buying I got a engine light pop up and I took it to a garage to get it diagnosed. They told me the variable valve timing solenoids need replacing and quoted me $1800 to repair, I have acquired the solenoid valves myself and plan to change them in the near future. The other thing is that sometimes when the engine is hot after a journey and it is in idle, the engine sounds a bit rough and like it’s almost going to stall.
My question to you all is, will there be any correlation between the issue I’m experiencing with the engine in idle and the VVT or is that another issue all together?
Thanks
shoro60
Northern Virginia
From my experience with the same issue, once you change out the solenoids, it goes away. I did the change myself once and didn't experience that again. I sold that Expy to my neighbor and it still runs smooth until today.
Brons2
Austin, TX
I would plan on doing a full timing job over just changing the solenoids. But, it won't hurt to try just the solenoids first.
I'm guessing the shop that quoted you $1800 was planning on more than the solenoids.
The symptoms you describe are well known issues in the 5.4 3V.
S
SDR93
canada
I’ll try the solenoids first and go from there.
They were going to change the spark plugs too which I think is recommended when doing this job but I checked them out and they look relatively new and clean so I won’t be changing them. Also they had priced for an oil and oil filter change in that quote but I already did that myself
Thanks for your reply
S
SDR93
canada
Cool, that’s good to hear, fingers crossed it’s the same for mine. I’ll post the outcome when it’s done!
Thanks for the reply.
Mikezr
Canada
I'd buy some vct solenoid gaskets as well if they didnt come with them and I'd doubt $1800 was for a complete timing job since the parts alone are a couple thousand. I got some quotes for the complete job just for fun and it ranged from $3500 to $5000 and not alot of shops wanted the job. Did it myself anyways. Going on two years now and still perfect.
Brons2
Austin, TX
Once the oil was changed does it still act up? Need to use 5w20 oil and a motorcraft filter.
Maybe ok for Detroit where you live and in Canada where SDR93 lives, but down here in Texas I use 10w30 and the engine runs a lot more smoothly when hot and makes less phaser noise as evidenced in the drive through. It also reduces the start up chain slapping, I guess it doesn't bleed out of the tensioners as fast.
I'm changing all the timing components soon. Need to do it before it gets hot, which is only a couple of months away here in the South.
Motorcity muscle
Motorcity
Did you notice any change in noise after oil change? Temperature has little bearing on how the VVT works.
S
SDR93
canada
I used 5w20 oil when I changed the oil and it’s making the rough idle noises before and after the oil change.
I’m currently in the process of changing VVTs will post an update when I’ve completed the change and let you know if it’s resolved the problem or not.
Thanks for all the replies, appreciate it!
S
SDR93
canada
Out of curiosity, how much does it cost roughly for all of the components to complete the full timing job?
Dustin Gebhardt
Tulsa, OK
Here is the complete set from a Ford dealership in the US:
You will also need a set of valve cover gaskets (these fit my '07, but the design is different for other model years):
I also purchased a high volume, high pressure oil pump from melling.
I also ordered a few special tools to do this job:
S
SDR93
canada
Update -
I changed both VVT solenoids and after doing so I took it for a long drive to test it out and it looked promising for a while but then the rough idle eventually happened again :-(. This aside I did find the car felt more responsive when I put my foot down.
I plan on keeping this car for around 18-20 months which is when I will leave the country, I’m not using it as a commuter so I doubt I’d do more than 15-20,000 miles in it. Is the rough idle a symptom of something worse that’s to come or is it possible that I can live with it and drive on and be able to squeeze a another year or so out of it? I paid 5000CAD for it so it wouldn’t be the end of the world if it’s not sellable by the end of my time here.
jeff kushner
North of Annapolis
FWIW: in both of my V8 expys, I experienced rough idles..............really crappy idles......running your hand under the vac lines on the passenger side of the engine, there is a 90 deg bend in a 3/8 or 1/2" line, the heel of the 90 rests on top of the valve cover and well, melts over time...as your finger covers the bottom and hold position, nice idle returns....a couple of bucks.....
S
SDR93
canada
Thanks for your message. I’ve had a little look but couldn’t pinpoint the exact part you mention, were your rough idles permanent or just intermittent and every so often when the engine is hot like mine?
S
SDR93
canada
I have now changed VVT solenoids and Camshaft position sensors - intermittent rough idle still persists :,(
Goofy173
Ky
Same problem here. 6 months ago I had everything on top and front changed at nearly $5k. Now the engine is basically toast and I've had it. Junking it.
JVinOlathe
Olathe, Kansas
Any work you can do yourself will save you a lot of money, provide you know what you are doing.
Have you hooked up a scanner to see if there are any codes? In the US, most auto parts stores will run a scan for free and print a list of condition and solutions if applicable. A scanner is as valuable tool, if not more valuable than any tool you can get.
I am pretty good with cars but also, I am aware of my limitations. Throwing parts until one solves the issue is not a good way to approach the issue. Your best bet is to take it to a competent mechanic, familiar with the Expedition, and with the proper equipment, get an accurate diagnostic and go from there; in the long run it will end up being more efficient and much cheaper.
"If you think hiring a professional is expensive, try hiring an amateur." - Red Adair
S
SDR93
canada
I used the scanner that my work has and this is what it came back with, if any can make anything of it.
I’m a plumber/ boiler engineer by trade and find I am capable of doing the work myself as long as it doesn’t require specialist equipment that I don’t have, so doing the work isn’t the problem, the problem is I don’t know what work I’m meant to be doing to do to solve the issue I Haven’t spent a lot on these parts but I’ve invested a lot of time just been changing parts on hunches which so far hasn’t really worked.
Thanks for all the replies btw, really appreciate it.
S
SDR93
canada
Damn that sucks.
I have been starting to wonder what would happen if I just left this issue as it’s an older car and the issue doesn’t seem too major or effect the performance but by the sounds it it’s a sign of something worse to come.
Was your issue identical?
Would just go in to a temporary rough idle after a long drive?
Did it throw up any codes?
Thanks
