Renewing 1st Gen Expedition - Cerakote
Aspen03
Indianapolis
Cerakote...like the coloring for metals?. I've seen blocks and firearms done...or is this a cleaner of some sort?
A steamer works wonders in this area fwiw, one with a pressurized boiler, not a $49 walmart special. It'll clean pretty much everything off the motor and you can then dress in your choice of whatever makes your day. I like G6 from Chemical guys because it doesn't attract dirt and gives a "factory" finish, not too shiny. At 242k I'm not going to any shows with my 03 and keeps it looming good for most of the year.
Whatever it was you used, big improvement and looks 10x better than before pic.
jr1under
jr1under
Aiken, SC
Same company but this product is a coating vs. coloring agent.
While renewing my 1999, I also applied it to the running boards and some other exterior trim with satisfying results. It's the only plastic trim restorer I've tried that works exactly as advertised when it's used exactly as directed.
jr1under
jr1under
Aiken, SC
