vehicle knocking while idling, but otherwise runs great, ??
zoldos
the US south
My check engine light has *not* flashed in months. I do however notice when idling, it knocks. But when I get going, it seems to run great.
Does anyone know what this means and how to fix it? I was going to use Seafoam, but I wanted to ask here first. Thanks!!
Hamfisted
Ft Lauderdale
How many miles on it ? What weight oil are you using ? Over 100k you should be using at least a 10w-30 maybe even a 10w-40 depending on climate.
Use Motorcraft oil filters too. ( Walmart ). Can you tell if it's a knock from the bottom end, or the top ?
Fastcar
Army
FL
What you call a "knock" could be "tapping" to others. Could be a rocker, lifter or bearing. Could be a loose bracket hitting against something. Try to isolate it, does engine temp play a part? You have to do some diagnosis yourself so others can try to help.
zoldos
zoldos
the US south
I think it's the top. I use 5W-30 as specified on a sticker on the engine. What is the difference? Oh and it has 161k miles. :)
zoldos
zoldos
the US south
Hmmm......it's not just a light tapping sound if that's what you mean. It "knocks" pretty hard. And it's only started doing it a few months ago. The engine temp is always below the mid point.
I don't know how to narrow it down. I don't know anything about trucks. :(
Fastcar
Army
FL
Then you should take it to somebody you trust that knows what they are doing. If it is a hard knock at low rpm and goes away as you rev it, you could be in for a world of hurt. Try going to a heavier oil. Again find somebody who knows what they are doing. Folks here can give all kinds of thoughts that may or may not be correct, because coupled with the lack of info and how many parts could make the noise you'll be chasing your tail forever as well as throwing money around.
zoldos
zoldos
the US south
Okay thanks! I will cut my use of it and take it to the shop....
mbtech2003
capecod
Being it say you need 5-30. That is what you use. Knocking at idle could be a number of things. If your oil pressure is low. It takes really low oil pressure to knock. If the oil pressure light isn’t on. With out putting a pressure gauge on it. You won’t know. As I think it is a 5psi pressure switch. They are known to have timing chain tensioners leak and cause the the chains to slap around breaking the guides. Is there a video you can post of it?
zoldos
zoldos
the US south
Something like this: https://www.oreillyauto.com/detail/...dition?q=oil+pressure+gauge+(universal)&pos=1 ? If it's low, what do I do next? Take it to my mechanic?
How do I check that?
zoldos
zoldos
the US south
Anyway, thanks for everyone's help! I'm just going to take it to my mechanic.
purevw
When I tossed a rocker on number 7 cylinder, it first manifested as a fairly loud knock before the engine warmed up. It actually sounded like a spun rod bearing, but the fact that it quit as temps came up and it only did it at idle eliminated that idea. After a period of time, I started getting cylinder 7 misfire codes. I found that at highway speed, the engine can breath well enough for the injectors to correct the mixture even with a single intake opening, but at idle the mixture often wasn't correct enough to produce ignition. Thus a misfire.
Vincent Vega
Huntington Beach, CA
@zoldos Could be alot of things but 05s often have problems with the timing chains, cam phasers, and related parts. Oil pumps were undersized, too. Let us know what the mechanic says. Good luck.
zoldos
zoldos
the US south
Thanks you so much! I just ran it for about 5-10 mins, and I realized it doesn't really "knock", but just runs a bit rough (which seems to be what it has been doing along). For example, I revved it up (in Park) and when the RPMs ramped up, and then when I eased off the gas, it sounded rough. I used my code reader and it said the Fuel Tank Evaporative High Pressure system is messed up. I already knew this, and am planning on getting it fixed. Would this cause the roughness? Last time I had it looked at, the mechanic said I probably would not notice it too much, but to get it fixed when possible.
Vincent Vega
@zoldos The #1 cause of misfires (running rough) on these engines is bad coils and/or spark plugs. The coils are integrated into the rubber boot that fits over each spark plug. Using a scope, your mechanic could easily track down if it is a coil/plug and which are bad. If it needs coils, spend the money and get Motorcraft. They are about $40 per. Cheaper ones are available, but many are defective even when new (lots of posts from frustrated cheap-coil people on here). You can replace just the bad coils, or all of them. Could also be cam phasers or dirty Mass air flow sensor, or in worst case timing issues or fuel system issues that will take more work to diagnose. I have not heard of the evap system problem causing misfires, but I would fix that first and then double check. Let us know what you find out.
zoldos
zoldos
the US south
Okay gotcha. The engine light did flash months ago which I was told is caused my a misfire, but then never did it again. But something is definitely messing up. .. thanks!!
mbtech2003
capecod
