Brake lights stopped working.
conner5255
Oregon
2016 EL Fleet.
Turn signals, flashers, tail/marker and 3rd are working fine. Looked at all fuses, all ok, replaced brake light switch, replaced bulbs. Tested for ground, all good.
Power to bulb for turn signal but not brake lights.
I do have Forscan available, but I am not sure where else to go.
Anyone have experience with this? Or any ideas?
2016 EL Fleet.
Did you use a Motorcraft switch?
Most brake light switches require that they be “set” when being installed. You hold the pedal back while installing the switch, then push it forward with your hand (engine off), then pull back.
Did you do this adjustment?
Did you manually use your finger to push the switch plunger in while a helper watched the brake lights (as a test of the switch and circuit)?
C
conner5255
Oregon
With the way the switch is installed not sure that I would be able to do this with the vehicle off.
I will take another look to see.
Also, the switch is activated as you push the brake, the plunger on the switch extends to cause the connection.
C
conner5255
Oregon
Also, I watched a couple YouTube videos and consulted a tech manual and none described "setting" the switch. All said basically plug and play.
Hamfisted
Ft Lauderdale
If your third brake light is working, the brake switch is working. Do you have brake lights at the trailer plug ? They share the same brake light circuit. Grey/Brown wire for left, and violet/ orange for right side. If not, it could be the circuit in the fusebox itself...
Logan97
AZ
Had a similar issue in my 07, there was a wire on the passenger side that ran down the floor to the back that had to be fixed. YouTube it, not hard to get to just make sure you tape it up real good so it doesn't happen again.
